AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official 2012 Sharp LC-XXLE640U/XXC6400U
Official 2012 Sharp LC-XXLE640U/XXC6400U - Page 29
post #841 of 1133
SILVERFOX1 Re; post#596
I tried several of the settings suggested on this thread including CNet's( movie), Z=Mad's (Game) and the settings you posted( STD). I must say ,while all of the setting were a great improvement over,out of the box but, for watching generally all of the content available on this Sharp LC-60LE640U I liked your setting the best!!! I did dial down the film mode to 0 and I'm loving it!!!
I made no other adjustments in the advanced sub-menu (HUE,Saturation,or Value). I left them at the factory default. Did you make any other adjustments in the advanced sub-menu? The Sharp 640U is matching my 2008 Sony 52" KDL XBR4 perfectly. Thanks for posting your easy Setting!!! They work GREAT!
Edited by evening flyer - 2/19/13 at 11:18pm
post #842 of 1133
I'd just be wary of the fact that out of the box CMS settings on all TV's are often largely inaccurate and need quite a bit of adjusting, otherwise your colors may be far from the true tones that they should be, which is one of the main aspects of any calibration. Just putting that out there if you're looking for the ultimate picture quality. BTW, not saying you need to use the settings that worked for me personally, just saying you might want to look into some CMS adjustments of your own to avoid inaccurate color tones. Anyway, whatever works for your enjoyment of the TV biggrin.gif
post #843 of 1133
@Moofi
The only way to get rid of the video lag is game mode with all motion enhancements off. I'm assuming you have an audio lag which is making it seem worse than it is. And for god's sake, put your brightness back to 0 or +1 and turn down the damn back light. biggrin.gif
post #844 of 1133
Originally Posted by Monte71 View Post
@Moofi
Ha ha, I have to agree! biggrin.gif No offense to anyone's personal preference if that makes them enjoy their TV (by all means), but these in-store advertisement settings (or torch settings) create false perception of what a good quality picture is for many people. The whites are like looking directly at a bright flashlight rather than an actual white color on a TV screen (and then people wonder why they see so much clouding or blooming). The blacks are artificially dialed down for perception of deep blacks and high contrast rate, but they kill all dark details, etc (-9 on brightness definitely kills all of shadow detail). The picture shines like a torch, but actually looks very unnatural and actually "flat" by killing all detail. It certainly isn't what a good viewing setting or good PQ is (certainly no professional calibrator would ever adjust the picture that way).
Here is what I found as essential for good PQ on this TV (and what any calibration disc will lead to as well):
I found that "contrast" (the adjustment of whites) shouldn't really exceed +32 (+33 max), otherwise you'll start losing white details.
"Brightness" (the adjustment of blacks) shouldn't really go below zero (maybe -1 at the lowest depending on source), otherwise you loose the dark details. 0 or +1 seems the best setting.
Game mode is indeed the only good mode that has none of the awful motion enhancement and soap opera effects, as well as lag issues.
"Backlight" can be increased just a notch for a bit extra brightness, but not more than maybe +2 or +3 (leaving it at "STD" is actually fine).
Of course CMS and "Color" settings need tweaking for the proper color tone accuracy and color luminance.
This is what it really boils down to for getting good PQ on this TV, with maybe slight variations depending on the set and source, but I wouldn't expect much variation at all in terms of brightness, contrast and backlight for example...
Edited by Z-Mad - 2/20/13 at 12:22pm
post #845 of 1133
When I was looking at the 640u in various stores often the TV was in the Dynamic Fixed mode. Talk about crappy picture. Almost like they didn't want to sell it. When the TV was delivered to my home, the set was on Standard which is pretty much everything at zero. So far I'm pretty happy with the picture and found some great info in this discussion about the set before I bought it including the various settings people were using.
post #846 of 1133
And in case any new buyers don't know it, Sharp.com offers various type of warranty add ons. I extended my one year warranty to four years for $120. But I think you have to sign up within 30 days of purchase.
post #847 of 1133
Yes Z-Mad ,I know you are correct. I'm still using your settings most of the time. It's been fun experimenting with the different setting using different A/V modes. I've found David Katzmaier's settings over at C-Net a very good starting point. I just seemed to think his setting were a little too dark and seemed to have a slightly green tinge. I made a few slight adjustments to his settings to suit me. He uses the Movie mode and the slight changes i made were Back-light +1,contrast +32,Brightness 0, color+2, Tint+2. In the advanced menu I only adjusted three items,C.M.S. Hue R:+10,Y-3, and in the C.M.S.-value y +3. All of his other adjustments I left as he had them. I enjoy watching Movies using these setting.
As I speak I'm watching Dream House on HBOHD using your (Z-Mad)setting(Game). The only change I made to your setting was color temp. I set it to mid low. The picture using your setting is excellent! However, I would like to brighten the picture up just slightly. ( any suggestions?)
When I stumbled upon Silver-fox's setting I thought I would give them a try as they were on a different A/V mode (Standard) I have to admit his settings kind of blew me away with all the picture pop it produced. The only change I made to his setting was to lower the Film mode Advanced mode to 0. I have noticed the picture looks a little grainy up close and maybe the colors are slightly gaudy.
So,it looks like now that I have done some more reviewing of the different settings and checking with the wife I'll be using Z-Mad settings with the slight adjustment I made to suite me. Thanks again for sharing your settings. I'm a newbie at this and it's been fun, educational and interesting. This is a great forum! Bill:)
post #848 of 1133
Good basic info, I agree 100%. The Sharp 640 definitely looks the best with these guidelines. I think a lot of people have become conditioned to think excessive backlighting, color, coolness, & sharpness equals good PQ ---- probably because they are like that in the store and used to come out of the box that way. Once you get used to a natural & realistic picture, you"ll never want to go back.
When I watch TV away from home, I want to get a hold of that remote so badly. I can't stand the blinding blue-whites, over saturated color, and jagged edges on so many TVs.
post #849 of 1133
Hey Z-Mad ; Just one more question. Which A/V mode do you suggest for watching a movie from Netflix? Game mode is not available with a PC input, so I'm using user A/V mode with the same setting you had for the game mode. I turned the film mode off. Your thoughts please.
post #850 of 1133
If you are using a PC to watch netflix I would connect the PC to the tv via HDMI, even if that means buying a low end radeon 5450 card to do so, this will allow you to use game mode, or any other mode you like that may or may not be available in PC mode. Or if you are using a DVI output on your PC, I would use a DVI to HDMI cable.
post #851 of 1133
Wow, really??? I just paid $500 for warranty at hhvregg. Looks like I'll be cancelling since I'm still within my 30 days
post #852 of 1133
[quote name="GlocksRock" url="/t/1399227/official-2012-sharp-lc-xxle640u-xxc6400u/840#post_22993482"]
Z-Mad
If you are using a PC to watch netflix I would connect the PC to the tv via HDMI, even if that means buying a low end radeon 5450 card to do so, this will allow you to use game mode, or any other mode you like that may or may not be available in PC mode. Or if you are using a DVI output on your PC, I would use a DVI to HDMI cable.[/quote]
OK Thanks. I see newegg.com has this one for $29.99. SAPPHIRE Radeon HD 5450 1GB 64-bit DDR3 PCI . Right now I'm using the built in WiFi in the Sharp 640U.Z-Mad'ssettings on user mode are producing very good results. Running a Hdmi cable from my PC would be difficult. If you ever have time, would you or Z-Mad please try using settings Z-Mad set up on game mode on user mode while watching Netflix on WIFI and see what you think? Thanks for your help.
post #853 of 1133
I agree with GlocksRock, I'd suggest to find a way to hook up your computer via HDMI. That's what I do too. I couldn't tell you which other mode may work well with the TV app since I really don't use it, but I might play with it a bit for fun and out of curiosity and let you know what my thoughts are...
post #854 of 1133
$150 for 4 years sounds like a great deal. I would just suggest to check what exactly the extended warranty covers for $150. The more expensive ones from 3rd party cover basically everything, including dead pixels and just about anything that can possibly go wrong with the TV, including easy replacement in most cases unless there is an easy fix. The cheaper coverage may just extend some of the basic things. I of course wouldn't know for sure in this case, but between $150 and $500 I'd expect some differences in coverage... Just make sure you're getting the kind of coverage you actually aimed for...
post #855 of 1133
... However, I would like to brighten the picture up just slightly. ( any suggestions?)
Yeah, it's fun to play with the settings and watch the results, so certainly enjoy smile.gif In terms of extra brightness and pop, try these if you like, as I bumped up some values for a bit of that extra pop while still maintaining all the details and colors):
AV MODE: GAME
OPC: Off
Backlight: +3
Contrast: +32
Brightness: 0
Color: +4
Tint: 0
Sharpness: +1
--Advanced sub-menu
C.M.S. -Hue
R: -9
Y: -2
G: +6
C: -13
B: -16
M: +10
C.M.S. -Saturation
R: -15
Y: -6
G: -18
C: 0
B: -9
M: -6
C.M.S. -Value
R: -4
Y: -3
G: +10
C: 0
B: +12
M: -2
Color Temp: Low
R Gain (LO): 0
G Gain (LO): +3
B Gain (LO): -7
R Gain (HI): -5
G Gain (HI): 0
B Gain (HI): -6
post #856 of 1133
You're right. The extended warranty through sharp seems to cover everything but I'm still reading it over
post #857 of 1133
Z-Mad; I have plenty of HDMI outlets on my Dell XPS. I would have to use a HDMI cable at least 35ft long. I'll check into the cost for such a long cable but,as I said earlier your settings for game mode still looks excellent to me on User Mode using the built in WIFI. However, I'm not very experienced when it comes to judging picture Quality but, your settings look really good to the wife and I.
So, I would really be looking forward to your thoughts if you find time, to try viewing the Sharp with the built in WIFI. Thank -you very much for the additional settings. They were just what I was looking for!
post #858 of 1133
Yeah, 35ft of HDMI cable wouldn't be cheap. I tried the exact settings as posted above only in user mode, and actually they did translate well to some surprise. The PQ is really good on netflix with these settings in my opinion. I'd just make sure all the enhancements are turned off (motion, active contrast, film mode, digital noise reduction). I did notice how slow the TV app really is, in terms of navigating through content etc. That's also one of the reasons why I prefer the computer, but if you have to use the TV app, these settings in user mode would be totally fine IMO and as they look on my set at least... Hope this helps your netflix solution for now smile.gif
post #859 of 1133
AV MODE: GAME
OPC: Off
Backlight: +3
Contrast: +32
Brightness: 0
Color: +4
Tint: 0
Sharpness: +1
--Advanced sub-menu
C.M.S. -Hue
R: -9
Y: -2
G: +6
C: -13
B: -16
M: +10
C.M.S. -Saturation
R: -15
Y: -6
G: -18
C: 0
B: -9
M: -6
C.M.S. -Value
R: -4
Y: -3
G: +10
C: 0
B: +12
M: -2
Color Temp: Low
R Gain (LO): 0
G Gain (LO): +3
B Gain (LO): -7
R Gain (HI): -5
G Gain (HI): 0
B Gain (HI): -6
I was already running your other sertings but tried these out and enjoyed these more. One thing I noticed is that in game mode, there tends to be a lot more motion blur than in any other setting. I also noticed this is only visible on dark scenes or anything with a dark color. Say a burgundy or brown jacket or shirt moving on the screen will have very noticeable motion blur when in motion. So I put these sertings into standard mode and turned film mode off and actually put motion enhancement to 120hz high and now that motion blur is almost non existent on the same scenes but no soap opera effect and still an awesome picture.
post #860 of 1133
Here are a couple 35ft. HDMI cables, not super cheap, but not too expensive considering the length.
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10240&cs_id=1025005&p_id=6055&seq=1&format=2
http://www.firefold.com/35ft-HDMI-Cable-Ethernet-3D
But considering all that you can do with a pc hooked up to your tv, it's well worth it. VLC will play pretty much every format out there, and having a physical keyboard is also very nice.
You said you have plenty of HDMI outputs on your XPS, don't you mean you have plenty of USB outputs? I don't see why a PC would have more than one HDMI output.
post #861 of 1133
Yeah, the motion enhancement feature is there to attempt to reduce any motion blur. It's just that it creates a bit of artificial looking motion as it is digitally generated by the TV and not originally shot like that with the camera. Personally, I found that I don't really notice motion blur myself (since the TV's native refresh rate is already 120Hz, plus it may depend a bit on the source/signal quality too), and if there even was some in the background of an occasional darker fast panning scene (I must say didn't notice it at all during sport), it is for me far less disturbing than the artificial motion that's noticeable 100% of the time. But again, that's just me, I'm kind of "sensitive" to that motion stuff and all about naturally looking picture biggrin.gif. Certainly you have found the tweaks that work best for you with still great picture quality, and that's what counts. Enjoy smile.gif
post #862 of 1133
Wow, not bad, 35ft HDMI for under $30. Cheaper than I'd expected. I'd definitely get my PC connected via HDMI. Totally agree with you about advantages of having the PC for any "apps" you can think of and web browsing. With a little inexpensive wireless keyboard and mouse, you're all set...
post #863 of 1133
Er.. yeah, your correct, I was thinking USB. Dud. I do have a empty DVI connection on the back of the tower. I'll try your suggestion, using a DVI to HDMI cable. Thanks for your links to the cables.
BTW, while doing some shopping at Target yesterday I just happened to pass through the electronics section and I notice the price on the Sharp LS-60LE640U was back up to $1,499.00. A few weeks ago the price had dropped to$1,199.00. I picked mine up at HH Gregg for $1,049.00 three weeks ago. I don't know why a 2012 set is back up close to the original price.
Edited by evening flyer - 2/22/13 at 5:12pm
post #864 of 1133
While I use Netflix through my Xbox and so it is on the game mode, I have set up the user mode to mimic Z-Mad's game mode settings through USB as I use that all the time to watch stuff. I think the quality on the user mode is pretty much exactly like game mode.
post #865 of 1133
I agree. But when I play a game, I put it on game mode to reduce lag.
post #866 of 1133
Zmad - update on my motion blur in game mode. I tested it last night. Watched end of watch on blu ray. Almost unwatchable in game mode even with your settings. The movie is a good way to show and dark scenes on game mode will have a tremendous amount of motion blur. Almost to the point that people almost disappear into shadows and dark shots altogether when fast motion is present.
But I noticed on standard mode or use mode with your settings with motion enhancement to high, and film mode on off, the motion blur was almost gone. Not completely but acceptable for an lcd.
But if u haven't seen end of watch, it's a good way to see the dark scenes blur/smearing going on. My 600u had this problem but due to its lsck of adjustments, I couldn't fix it. Thank god I swapped it out for the 640u
Oh, and no soap opera effect
post #867 of 1133
Just as long as you know that you won't get audio with DVI-HDMI cable, you will sitll have to run a separate cable for that.
post #868 of 1133
I've got my LC-70LE640U few weeks ago. Was reading this thread before and after the purchase. Got a lot of useful information. Now, I am generally happy with this TV, but it has few minor issues. And since I have just one week left for easy return, I want to see what everyone else thinks about these issues.
First, there is a diagonal line of light that is very noticeable on white and some other solid colors. Everyone in the family can see it in some commercials, when there is a smaller logo on a big solid background (for instance, Apple ads). Below are couple of screenshots. Taken with the phone, no processing.
Second, is bright clouding in two lower corners. Less noticeable than the first issue. Annoying in letterboxed (2.35:1) movies in dark environment. This one also taken with the phone, levels slightly adjusted.
I know that edge-lit LCD TVs have some limitations and clouding is expected. Is mine within a norm? And if I exchange this unit replacement could have similar or even worse problems. Or are these issues too much and I should return this TV?
Any feedback appreciated.
post #869 of 1133
The diagonal line is definitely not the norm. Get the TV exchanged with another one.
post #870 of 1133
Hey leroy lee, thanks for the update. Sure, game mode without any motion enhancement is not perfect in terms of motion blur. My or any other settings would not be able to help that. Certainly depends on the content how noticeable it is. I may have not noticed it much, but I know it's not non-existent of course. I'm glad my settings actually translate into standard mode too, so in case motion blur becomes a problem, there is an alternative. Thanks for the end of watch example, I'll check it out too and play a bit with the other modes (like standard). Good to hear soap opera effect doesn't seem noticeable. I'll give those other modes a try too and explore the TV's potential... Thanks wink.gif
