Hi! I have a room 9"x10" that I will be attaching two sheets 5/8" sheet rock (with green glue) to the ceiling on hat channel & whisper clips. The joists run parallel to the 9" walls. I'm wondering what my configuration and spacing should be for the hat channel and sheet rock. Given the 6" from the 10" wall on either side, I can run 3 more rows of hat channel spaced 24". I figure I'll have to space them less since I need at least 3 sheets of 48" wide drywall running parallel to the hat channel and each sheet needs at least 2 rows of hat channel(?). Any help configuring would be appreciated, thanks!
AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Hat Channel Ceiling questions
AVS Top Picks
