AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Samsung UNxxES8000 Owner's Thread
Official Samsung UNxxES8000 Owner's Thread - Page 399
post #11941 of 15252
Originally Posted by Anthony5362 View Post
Sorry it took so long to reply. We're all deeply involved with this whole calibration since some old settings seem to be way off..
Yes, keep those enabled on both your TV and blu ray player. That's what I do anyways.
As far as your 65" only you can decide they my man. Its up to you if you notice it under normal viewing conditions or not. If this is all your going to see and think about, then yes, I would get rid of it and either try the 60" or another 65" or even wait for the highly expensive F8000 when it comes out..
TBH i dont really notice it all that much during normal viewing will stop thinking about it and just enjoy the tv
post #11942 of 15252
Are you guys going to do standard mode as well? I hear that one is harder to calibrate. Maybe because of the Micro Dimming and Ce dimming?
post #11943 of 15252
I really think its because you have a different model then us. Different contrast ratio etc,.the 7500 is a different TV. It looked exactly the same though I hear before the latest update, but I think they are different now. I was thinking maybe to save some money and buy a 7500, but I think Im going to either get the 8000 or just wait for the F8000
Very very very possible. What does 10k have? Even more than model, it may be panel size an type. but I do have good improvements with this update.
post #11944 of 15252
Just ask yourself if from a year from now if you will still be in this honeymoon phase and if not then swap it. Or like you said, just enjoy it. I don't know what your financial situation is, so I don't know how long you plan on keeping this TV. I don't mind mine anymore because I usually upgrade every year..lol! But I have to stop that. Its like throwing money out the window.
post #11945 of 15252
Originally Posted by Jestered View Post
Also, I've talked a lot about the calibration process, but haven't really said anything about what it did to my PQ. Was it worth it? Absolutely! Is it night and day from what I had it looking before? Not really. If I had to guess I would say that visually it is probably about a 8% improvement in PQ. Not bad considering that I LOVED how it looked before and it took me a long time messing with settings just to get it there. Also, I was worried that it was going to dull down my colors and I wasn't sure how I felt about that because I like a little pop. Well that was not the case at all. My colors look outstanding! A metered calibration will definitely add that little extra umph to your TV that simply isn't possible without a meter and good calibration.
A few pics I took after the calibration:
post #11946 of 15252
Guys, there's a new update on that THX app for the iOS
post #11947 of 15252
now we are talkin. It looks to me that this panel calibrated to specs has plenty of punch and isn't watered down at all. i definitely need to do this.
post #11948 of 15252
post #11949 of 15252
me?
post #11950 of 15252
updated 5/12/13 - settings are at the bottom of this post
This post contains my efforts at calibrating my TS01 panel 55" ES8000 with an Xrite Colormunki Display
Many thanks to Turboman, prsut, jestered, and all the awesome members of this forum for helping me figure out how to do this and offering their time and knowledge throughout
Tools used:
Forked version of HCFR: http://sourceforge.net/projects/zoyd000.u/files/downloads/ updated 2/22/13
HCFR forked version discussion thread: http://www.avsforum.com/t/1393853/fork-of-hcfr-started-whats-needed/1380
Kal's guide to HCFR: http://www.curtpalme.com/forum/viewtopic.php?t=10457
AVS 709 Calibration mp4's: http://www.avsforum.com/t/948496/avs-hd-709-blu-ray-mp4-calibration
NVIDIA RGB FullRange Toggle - https://forums.geforce.com/default/topic/523992/tip-for-nvidia-users-using-hdmi-and-getting-accurate-color-format/
NOTES ON HTPC USE
The main use of my TV is connected to HTPC. I watch cable through Windows Media Center and an HDHomeRun Prime cablecard device. My HTPC has an NVIDIA card which by default will only do 16-235 RGB range, which causes problems with video vs desktop applications. Using the toggle tool above you are able to force 0-255 mode for all video and apps. I have that toggle set to "full", and my TV and avr set to HDMI "normal" (0-255).
In NV control panel
Video->Adjust video color settings->advanced->Dynamic Range: "0-255"
Display->Adjust desktop color settings->Digital Color Format: RGB and content type: fullscreen videos
This should make it so games, web video, cable, and bluray all use the same color range. I did some spot check measures of my calibration against using the MP4's via usb stick and all looks well.
NOTES ON DYNAMIC SETTINGS
I did some limited testing on dynamic contrast, black tone, and black enhancer using the meter and the following reference images - http://www.avsforum.com/t/1466036/calibrators-lets-talk-shadow-detail
Dynamic Contrast
I can see how dynamic contrast set to low might be able to enhance overall picture quality. Unfortunately it is basically impossible to "calibrate" since it is dynamic in nature. I dont think using APL patterns really helps since you are just hiding the dynamic contrast function by measuring those patterns. Having this on to any degree does appear to crush blacks to a certain extent, but the benefit is that you get a better range of bright color detail. Unfortunately it never goes the other way in providing any extra shadow detail. So maybe there is an arguable improvement, but you are really trusting that Samsung got it right in how they programmed it.
Verdict: Off, Low if you trust Samsung
Black Tone: As far as I can tell, this does nothing but crush blacks.
Verdict:Off under all circumstances
Black Enhancer
The effect of this is subtle and difficult to measure. I suspect that turning this on enables standard mode CE dimming to a degree inside movie mode. Overall contrast appears improved slightly with this on, and I cannot detect any negative impact in other readings.
Verdict: On? Off if the CE dimming in Standard mode bothers you
WHICH PICTURE MODE SHOULD I USE?
A few notes on calibrated standard mode vs movie mode now that I have been using Standard for a few days.
+Standard mode visibly and substantially reduces, but does not wholly eliminate, clouding and flashlighting due to the CE dimming effect.
+Shadows in many scenes appear "blacker". It's hard to describe but while movie mode does an excellent job of displaying all intended shadow detail, certain shades of black can sometimes appear a little "hazy". In comparison, Standard mode dark areas are deeper and more "shiny". A good area to see this is to watch a hockey game and switch between the two while paying attention to the shadows behind the glass surrounding the rink. I believe this is due to realtime gamma adjustments being done in standard mode to get as much contrast out of every scene as possible, while Movie mode has a more constant picture processing.
+Color accuracy is nearly as good in Standard Mode as movie mode. Color luminance tracking is better in standard mode, with a more linear tracking of color brightness from dark to bright. For some reason, movie mode on my set is too bright at 75% saturation and not bright enough at 100% saturation in Blue, for example.
-Brightness pops in scene transitions. I really noticed this watching Mad Men this week. There were a few quick cuts between a bright scene and then a dark one with Don in the hotel room. When the dark scene came on the TV took about a quarter of a second to adjust the backlight brightness, creating a weird effect where you see the dark scene and then its almost like someone turned down/off the lights in the room. It was distracting to me but my wife didnt notice. This is probably the biggest flaw of Standard mode.
-Some minor loss of shadow detail due to the always on dynamic contrast elements of Standard mode. Easily visible on a still image but not readily apparent in moving images.
-Bright scenes in wide aspect movies still have nearly the same level of clouding and flashlighting in the black bars on top and bottom.
-Color accuracy is worse in green, and to an extent magenta. Especially in green, the color tracking is nonlinear and has a "twist" which makes it impossible to get green the correct hue across all saturations. It is hard to say how much of this flaw is actually visible when watching content though.
-I have noticed, but not tested, that Standard mode appears to have more lag than Movie mode. I never had to adjust audio offset in my receiver in Movie mode but some content in Standard mode was just desyncd enough that it was noticeable and slightly annoying.
Conclusion: For anyone watching in a light controlled environment where they are able to set backlight somewhere around 5, Movie mode is almost certainly superior as it gives a consistent picture and at those backlight levels I see nearly no clouding or flashlighting at all.
For all other uses, and especially for people with open windows, Standard mode is a clear winner if you can get past the annoyance of occasional brightness weirdness in scene transitions.
SETTINGS:
Complete
standard mode measures.zip 4k .zip file standard mode settings 5/12/13 firmware 1051 (Click to show)
Standard
Backlight 8 (37ftl) to 11 (49ftl)
Contrast 70
Brightness 44
Sharpness 15 (preference)
Color 50
TInt 50/50
ADVANCED SETTINGS
Dynamic Contrast Off
Black Tone Off
Flesh Tone 0
Gamma -2
Motion Lighting Off
WHITE BALANCE
26 25 22 24 34 1
COLOR SPACE Custom
Red 31 3 0
Green 6 51 0
Blue 0 4 48
Yellow 51 48 3
Cyan 3 49 54
Magenta 31 5 47
PICTURE OPTIONS
Color Tone Warm2
Noise Filters Off
HDMI Black Level Normal (set for your equipment)
Auto Motion Plus Clear
LED Motion Plus Off
Standard mode calibration charts (Click to show)
movie mode settings 4/19/2013 bt1886 gamma firmware 1048 (Click to show)
Backlight 8
Contrast 100
Brightness 45
Sharpness 15
Color 50
Tint 50/50
ADVANCED SETTINGS
Black Tone Off
Flesh Tone 0
White Balance 27 25 18 35 49 31
COLOR SPACE (Color, R, G, B)
Red 48 0 0
Green 5 47 5
Blue 0 5 45
Yellow 51 48 3
Cyan 3 49 54
Magenta 43 5 44
10pt White Balance (Interval, R, G, B)
1 0 1 5
2 1 1 2
3 1 1 1
4 2 1 0
5 3 2 0
6 1 2 -1
7 2 2 1
8 0 1 0
9 1 1 1
10 0 0 0
Gamma +1
Black Enhancer Off
PICTURE OPTIONS
Color Tone Warm2
Noise Filters Off
HDMI Black Level - whatever is appropriate for your equipment
LED Motion Plus Off
Calibration charts to come. In the meantime see this post -> http://www.avsforum.com/t/1399319/official-samsung-unxxes8000-owners-thread/14730#post_23222323
movie mode settings 2/24/13 bt1886 gamma (Click to show)
Picture Mode: Movie
Backlight: 8 (46 ftL) -or- 5 (30ftL)
Contrast: 100
Brightness: 45
Sharpness: 15 (Personal preference)
Color: 50
Tint: 50/50
ADVANCED SETTINGS
Dynamic Contrast: Off (frustrating/impossible to calibrate with on)
Black Tone: Off (Does nothing but crush blacks)
Flesh Tone: 0
Color Space: Custom
Red: 47, 0, 0
Green: 5, 47. 5
Blue: 0, 8, 45
Yellow: 51, 48, 3
Cyan: 3, 49, 54
Magenta: 43, 6, 44
White Balance: 27 25 21 41 50 30
10p White Balance (interval, r, g, b)
1 0 1 2
2 0 0 0
3 1 0 0
4 1 0 0
5 1 0 -1
6 1 0 -1
7 1, 1, 0
8 0 0 0
9 2 1 2
10 0 0 3
Gamma: +2 (see note regarding htpc, use 0 for bd/cable)
Black Enhancer: Off (on appears to improve grayscale after calibration, unknown impact elsewhere)
PICTURE OPTIONS
Color Tone: Warm2
Noise Filters: Off
HDMI Black Level: Normal (set as appropriate for your equipment)
Film Mode: Off (greyed out)
Auto Motion Plus: Clear (personal preference)
LED Motion Plus: Off
calibration results charts (Click to show)
Grayscale
Colorscale at 100% luminance
Colorscale at 75% luminance
Gamma
RGB Levels
CIE Chart
Saturation Tracking
work in progress
Edited by 10k - 5/15/13 at 8:34am
post #11951 of 15252
i don't know squat about this but i have started reading lots over at the calibration thread....which didn't help me at all with this random guess.
the main difference I can see bettween your settings and jestereds is in white balance and 10p. it looks like yours have more move in the gain than his and also more, maybe offsetting, moves in 10p.
post #11952 of 15252
CNET's Movie settings look like they are pretty accurate. As far as their Standard settings, the Pre-Calibration snapshot is more accurate than post calibration! Look for yourself
http://www.scribd.com/doc/101755962/Samsung-UN55ES8000-CNET-review-update-with-Standard-mode-calibration
I'm still using Nitra's Standard settings, but if I remember correctly his movie mode settings were pretty much the same as his Standard settings. So I'm looking into others now. Perhaps I'll just reset the default Standard mode and stick a little closer to those settings and work from there since they look fairly decent according to the pre-calibration snapshot in the link above
post #11953 of 15252
Here's some action shots. Definitely looking good. Calibrated Movie mode does reveal some clouding though in very dark scenes, maybe I will try messing with the dynamic settings to see if it can help reduce the clouding without compromising the picture.
post #11954 of 15252
I agree man, that's why way back in this thread now, I suggested to do this first then check for any differences and if there's still no difference, then do the full reset. Seriously, there's a lot to gain from this update so why not? Anyone need more proof about this amazing Bladerunner update, just check out the AVforums In the UK. Nuff said..lol
full reset ? how do you do a full reset?
post #11955 of 15252
please stop hating on us 8000 owners that have this super amazing panel now that we got the super amazing "bladerunner" update!
OK, i am lost, whats a bladerunner update?
post #11956 of 15252
bladerunner is a meber here and he never updated his tv but since this last update he has thats why there calling it the bladerunner update smile.gif
post #11957 of 15252
I posted that I would talk more about my 70 contrast setting in my calibrated settings, so here goes.
Contrast is not for setting your white clipping. Well, it is for non-meter calibration, but not really. Those calibration disks all tell you to make sure it's not clipping in a certain area, but that does not mean you want it to clip at that point. It's not the same as the brightness setting where you want it to clip in one exact spot. So, if you're trying to get the contrast setting to clip at the "white" spot in those test patterns, what you're really doing is setting it to the very worst you can without clipping into white, which is not what you want to do.
The contrast setting is actually setting the luminance level. The luminance level on these TVs should be set between 30ftL and 40ftL using a meter. I set mine at 40ftL, which put my contrast setting at 70. That's the highest I could set it without getting out of the preferred luminance range. If I had set the luminance to 35ftL, which is the center of the preferred range, I would have ended up with a contrast setting of 66 on the TV. So, setting the contrast at 100 like a lot of people do (myself included until I got this meter), is not the right thing to do and isn't helping your pic quality. In fact, when I first measured luminance with the meter, my contrast on the TV was set at 95 and I was getting a luminance reading above 120ftL. That shows you just how far out of the preferred range you are when setting the contrast that high. Unfortunately, you cannot measure the luminance level without a meter, so the only thing you can do is make sure white isn't clipping and then drop it down more.
hello Jestered,
I have a different take on this. Luminance is affected mainly by backlight setting and contrast. And minimum black depends mainly on backlight and brightness.
Target is to have maximum contrast ratio. This can be achieved by increasing contrast and reducing backlight, for a given peak white output. Contrast can be increased as long as no clipping occurs. Clipping is most likely to show if one color drops in level at 100% on the greyscale. Samsung has set the settings of the Movie mode quite conservative in order to prevent clipping. Standard Mode is not so conservative and you have to watch out for clipping.
But for Movie mode, I think you can set contrast high. I think 10ks value of 93 is good, and I have mine at 100 (post 8007), and still no clipping. With contrast maximized without clipping, set your backlight to get the target you want.
Brightness setting: select a picture with 0%black for measuring, but the whole screen should not be black to prevent dimming. APL picture is good for that. Set a higher brightness and measure. Lower brightness and measure. Continue step by step until black level does not reduce further. The highest brightness level where you reach that lowest black is the best. If you reduce brightness further, you crush blacks without reducing minimumblack level.
Also, no point calibration color and tint. All corrections can be done in the CMS custom color settings. Do the custom color settings at 100% saturation and 75% luminance (safer in case you have some clipping at 100% luminance)
post #11958 of 15252
Originally Posted by 10k View Post
OK it's getting late but I think I have gotten to a good spot with my calibrated results. This stuff is pretty fun, well worth the money spent considering I stayed in tonight instead of spending about the same amount at the bars, except now I get a nice picture on my TV instead of a hangover.
Here's my results file you can load into HFCR calibrated results.zip 6k .zip file
Grayscale results (check out those sweet delta-E's;) )
Colorscale results
CIE
Color Temperature
Gamma
Luminance
RGB Levels
Overall pretty good but I think the Gamma levels could use some work. Any suggestions Jestered?
Here's my settings, 55" ES8000 panel TS01
Mode: Movie
Backlight 10
Contrast 93
Brightness 49
Sharp 20 (not based on meter, use your preference)
Color 49
TInt 50/50
Screen Adjust - Fit
Advanced Settings
Dynamic Contrast Off (impossible/frustrating to calibrate with this on. Maybe turn on if you like it)
Black Tone Off (same as above)
Flesh Tone 0
Color Space
Red 48 0 0
Green 8 53 4
Blue 0 6 62
Yellow 59 53 5
Cyan 1 58 59
Magenta 49 3 54
White Balance
Offsets 27 25 22
Gains 22 25 5
10p White Balance
Interval, r, g, b
1, -1, 0, 0
2, 1, 0, 1
3, -1, 0, -1
4, 1, 0, 1
5, 2, 0, -1
6, 0, 0, 0
7, 2, 0, -1
8, -1, 0, 0
9, 0, 0, 1
10, 0, 0, 2
Gamma 0
Black Enhancer Off
Picture Options
Color Tone Warm2
Filters off
HDMI Black Level Normal (my htpc is configured for this)
Auto Motion plus Clear (personal preference)
LED Motion Plus Off
Jestered, if you have the time and inclination I"d be interested to see what these settings do to your panel measurements. Based on what we tried in the past page or so of this thread though, it looks like using settings across panel sizes is a waste of time. Anyone else out there with a 55" want to try the above?
hello 10k
That looks good, apart from Gamma. Jestered has a flat Gamma, and so have I. Cant explain yours.
A non flat gamma can be caused by the panel diimming. But with special modes off this should only occur in Standard. So for Standard, use large APL patterns to prevent CE-dimming. If CE-dimmng occurs, the gamma goes up at low light output.
But anyway, you have a Movie calibration, so your Gamma curve is difficult to explain.
Have you sed AVSHD patterns burnt on a disc, payed from a Bluray player? If not, try that. If you used patterns sent from a PC, then this might be a problem. Do not rust patterns from a PC unless you have crosschecked them with another source.
I also saw you did gamut calibration at 100% luminance. Recommended would be 75% to be on the safe side of not having clipping.
Take care.
Edited by turboman123 - 2/7/13 at 1:19am
post #11959 of 15252
Originally Posted by connerlq View Post
Plan on getting one of these mainly for blu ray movies, a pc monitor, and occasionally gaming.
Do Samsung TV's usually perform well as a monitor? I am currently using a Samsung 2770HD as a monitor and it has no issues, hoping that's the norm, not an exception.6.gif
Yes it's very good as a monitor & using amazing pictures off the web fro screen saver in 1920/1080 looks amazing.
gaming is also very good, i can't believe how much detail i was missing out on in diablo 3 using a 28" monitor.
There is 1 problem tho, u will NEVER like using a reg pc monitor again, stuff is too small looking & i was having a hard time reading stuff on the web using the 28" monitor.
after i lost my 50" c8000 i hated using a small 28" monitor,you'll prolly NEEVER go back to small monitors again.biggrin.gif
post #11960 of 15252
Originally Posted by turboman123 View Post
New thread for xxES8000 calibration settings?
Jestered now got his meter, se we are all looking forward to see his calibration results. Also the meter which I sent out on loan is new being used. For those who do not know, I had a meter and in the past, I proposed that I will loan that meter to whoever in this thread who wants to try calibrating their xxEs8000 panel, and report the results. Aim is to get more solid calibration settings. The meter starts now to getting used, so we can expect some reports. If anyone else is interested, just PM me.
Question is: should we start a new thread for xxES8000 calibration settings?
- having those calibration reports in this thread might swamp this thread with calibration settings, and not all users might be interested in that.
- on the other hand, a separate thread waters down the focus.
I propose we just vote on it. Look for the last post with this topic containing the last vote, then reply with "Quote" button, and add your user name and "separate thread" or "not separate thread".
That way, the last reply should contain all the votes.
Here is the result:
1000 separate
turboman123 separate
anthony5362 same
spacerpower separate
opsguy separate
bladerunner same
nick-t separate
marcojames separate
mavinwow same
arenaman separate
derekgosselin same
thebignewt separate
sharkcohen same
mickjcat same
garnoch same
quicknik same
postroad same
fleetski same
gamermwm same
7011jrs same
sympathetic separate
If I have made no mistakes, then it is 12 for keeping the same thread, against 9 for a separate thread. Of course, anyone can start a thread and these things do not depend on a vote. However, for the sake of having a lively community with members contributing, some co-ordination is helpful. In this case it means it would be best to keep calibrated settings discussions in this thread.
Thanks for all contributors.
post #11961 of 15252
Colorscale results
CIE
Color Temperature
Gamma
Luminance
RGB Levels
Mode: Movie
Backlight 10
Contrast 93
Brightness 49
Color 49
TInt 50/50
Screen Adjust - Fit
Advanced Settings
Flesh Tone 0
Color Space
Red 48 0 0
Green 8 53 4
Blue 0 6 62
Yellow 59 53 5
Cyan 1 58 59
Magenta 49 3 54
White Balance
Offsets 27 25 22
Gains 22 25 5
10p White Balance
Interval, r, g, b
1, -1, 0, 0
2, 1, 0, 1
3, -1, 0, -1
4, 1, 0, 1
5, 2, 0, -1
6, 0, 0, 0
7, 2, 0, -1
8, -1, 0, 0
9, 0, 0, 1
10, 0, 0, 2
Gamma 0
Black Enhancer Off
Picture Options
Color Tone Warm2
Filters off
LED Motion Plus Off
THX, i will try this out since i have a 55" TS01 also
post #11962 of 15252
jestered.
thanks for posting your metered settings.
I find them little to warm.
i have the same set. 55/ts01
post #11963 of 15252
Originally Posted by Derek Gosselin View Post
jestered.
jester has the 65, mine is the 55. I am going to take another pass today and try and get the calibration perfect.
Turboman, many thanks for your comments, they were very informative. I'm going to try calibrating at 75% luminance as you suggested to see if that makes a difference. I expect it will since my htpc is set to output 0-255 rgb
post #11964 of 15252
Turbo have you measured or changed anything since the 1046.2 update?
hello Derek,
I live in Hong Kong, and I have an Asian 55ES8000 with different firmware from North America.
post #11965 of 15252
Oh. sorry friend. thanks for posting 10k. I input your settings quickly before going to work and the picture seemed a little to warm. Looking forward to hearing of your futur findings with your new meter. Cheers!
post #11966 of 15252
hello Derek,
I was using your setting before the 1046.2 update and loved them but now the picture looks off, are you still on the same settings?
post #11967 of 15252
Well i have requested a panel replacement, Sent the Tech guy some pics will hear from him tomorow, But since i have sent the pics i now see banding on regular viewing other then sports just watch NCIS and could see the banding on certain scenes
The only thing we can really do with out loosing a TV for a couple weeks is panel replacement
Where i work we dont have the 60 instock id have to order it and can take up to 2 weeks but i have to give back the current one so no TV for a couple weeks
Another way i can not go with out is to call samsung and arrange for my money back and buy the 60" at a place i know has stock and come out of it with a 700$ back in my pocket
I was even supposed to get this calibrated next thursday so i had to put that of now to
Damn decisions
post #11968 of 15252
hello Jestered,
Blue clips bad in movie mode. I'm hoping a good cal will fix this.
post #11969 of 15252
hello Derek,
I am still using the same settings, but soon I will calibrate again. I calibrated up to now with my Sony BDP350 blue-ray player, which is 5years old. I kept on to it for a long time, because it is multiregion.
But now I bought an Oppo BDP103, which for sure will be better than the old Sony. So I will calibrate again with the Oppo blue-ray player.
post #11970 of 15252
hey shark
I did not get blue clipping in Movie, see my post 8007 or around that.
Where did you see blue clipping in Movie?
