Originally Posted by Jestered
You're right to some degree. The native refresh rate for the ES8000 is 240Hz. The CMR can be adjusted to get a max of 960Hz, which is what produces the SOE. Being that the 24 frames per second (24p) can be divided into 120Hz and 240Hz evenly, there's no conversion needed to natively display 24p content on the ES8000.
I've been messing around with the Auto Motion Plus settings and I've been seeing, what I assume is, artifacting when in the Smooth preset. Is that what it is? I'm curious exactly what the Blur Reduction and Judder Reduction values are for the Clear, Standard, Smooth presets. Do you have any idea what they are? I thought I read this information somewhere, but I don't see it anywhere. I really want to get the picture as fluid as possible with minimal artifacting(if that's what it is called). So far Clear seems to be the best preset, but if I can increase the fluidity a bit more I would be happy.
