AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Samsung UNxxES8000 Owner's Thread
Official Samsung UNxxES8000 Owner's Thread - Page 526
post #15751 of 16126
You guys are nuts. I'm still using a Yamaha sub I bought for $400 in like 1993, when subs were new. It's got 2 four inch drivers and a crossover knob. You had to bleed the front speaker wires through it because there was no sub output on AVRs then (Dolby Digital was the format, VHS the source). It still sounds good, but maybe it's time to upgrade? (I think I know the answer)
post #15752 of 16126
^ROTFL
post #15753 of 16126
Originally Posted by SoundofMind View Post
Either would be a fine sub and a good value. I don't know what a coupla Hz difference in F3 pointtranslates to in real-world listening.  You're right, 20-25 is felt, not heard.  Note that by placing a sub closer to a corner you can gain considerable sub performance with "room gain". The VDR is a 12" and has more sophisticated electronics w/ DSP and presets.  I personally use that feature all the time.  For ex., the music setting gives me accurate, smooth yet punchy bass, the Action Movie setting rattles the walls.  smile.gif
Hey, here's an idea.  If still available, order two of the Velos.  Same price as 1 SVS, way more power/headroom, WAY more speaker area-and you'll gain low freq extension.  if you like you can situate two subs to help cancel room modes created by either one for smoother, punchier bass.  Two subs is crazy good, especially at that price!
While you're at it, why not buy the "Butt-Kicker" chairs with the Sub connected.
Two subs, one on each side of the room with "Butt Kicker" lounge chairs to boot. That way, you'll really feel the movie....smile.gif
post #15754 of 16126
^My HT is on a suspended hardwood floor over a crawlspace so when I put my two Velodyne DD10s (combined 2500 W RMS) in "Action Movie" mode I get my "butt kicked" pretty good already.  :D
post #15755 of 16126
Originally Posted by zaria View Post
I also read that 3D tvs like ours can accept 120hz and display 120hz; is this true?.
When I output from HTPC I get 1080p 60hz; using Totalmedia Theatre 6 when I play a 3DBD it updates the refresh rate to 1080p 30hz and when I play using PowerDVD 13 I get 1080p 24hz on 3D discs; this is only on 3D content; is that normal and does the same thing happen if I had a external commercial 3D blu-ray player using this tv?
I couldn't find it on google but if you look in your manual you will see that the TV input is limited to 1920x1080@60hz, or 1080p60. All the marketing about 120hz and 240hz is around the processing that gets performed by the TV itself on the 60hz signal before displaying it (ie, the smoothing features etc). I dont know about TMT vs PowerDVD but if they are switching to 30hz and 24hz when you are playing bluray, it is doing that because that is the framerate of the source content. If it got it wrong and was playing 24fps content at 30hz (or vice versa) it would look terrible, so dont worry, it's doing what it is supposed to.
In terms of displays that accept greater than 60hz input, I think you need to look at PC gaming monitors for that. As far as I know no television accepts anything higher than 1080p60 (except the handful of 4k 30hz displays out there).
post #15756 of 16126
I have occasional stutter. It happens on a irregular basis on all HDMI inputs. I have read a few posts that suggest changing "AMP" setting to "clear". I am not home to check but don't recall seeing this in the menu. What is it and what am I changing? I won't be able to look at it until tomorrow. Other then this I love the set.
post #15757 of 16126
Yep. You likely need to change that to clear to resolve the studder problem. Here's where you'll find it:
Picture-> Picture Options-> Auto Motion Plus
post #15758 of 16126
This is EXACTLY what was wrong with mine. Took three repairs to identify it. The connection cable had a short, and one of the ends actually looked burnt when it was taken off. First two techs didn't notice it. 3rd Tech indicated that there was a service bulletin posted about this being the potential problem.
post #15759 of 16126
Well so far so good. "AMP" (Auto Motion Plus), changed it to "clear and all seems well. I have not seen any stutter. I'm not 100% sure but the picture looks a tad softer in clear. Anyone else notice that. It could just be my old eyes playing tricks on me.
post #15760 of 16126
Are you guys able to get dualview (or whatever its called) working with the Galaxy tab 2(or galaxy s3 for that matter)? My TV came with one as a bonus but I've never actually ben able to make it work, not sure what the deal is.
secondary note- im still extremely disappointed that allshare-cast (aka miracast) doesnt work without a silly dongle despite the TV having all needed technology already built in.
post #15761 of 16126
Dual view only works for non HDMI connections.
post #15762 of 16126
do any other connections actually exist?
post #15763 of 16126
You could do component, but HDMI looks the best.
post #15764 of 16126
i'm crazy confused. are you saying that SmartView only works if im using a connection that doesnt exist ?
Alls i want is to connect my fios box to my un60es8000 and watch the game when i have to run t he pooper. what am i doing that is wrong ?
post #15765 of 16126
SteFuel, i agree that clear does soften the pic slightly. I use standard. I dont have stutter but the occasional blur...but imho its easy to live with for the sharper punchier picture. Well worth the trade off.
post #15766 of 16126
I use to have my AMP setting set to Clear cause I would get bad stuttering in STANDARD. But lately after latest update FW 1057 I have it set to STANDARD and it's perfect smile.gif
post #15767 of 16126
Does anyone have or herd about the Samsung wall mount ? Supposly hangs the tv really close to the wall ??
post #15768 of 16126
Edited by Highland Logan - 1/3/14 at 3:39am
post #15769 of 16126
Hey
Originally Posted by Highland Logan View Post
There are 2 types; the Slim Mount and Mini Mount. I have the WMN350M Mini and it's great.
Frank
hey frank, what's the diff between the two ? I had bought a mount from best buy but I want a mount that sets the tv as close to the wall. Is there any heat issues being so close to the walls ?
post #15770 of 16126
Regarding SmartHub apps; is there a difference between the availability of the apps for US to Canada?
post #15771 of 16126
post #15772 of 16126
Yes there is quite a difference. I'm happy with what was offered for the Canadian apps. I get my channels (only 3) from OTA, so I'm not too hard to please. The only thing that got me was the lack of PVR/Timeshift, but I took care of that problem.
Frank
@Frank, thanks I just read your signature post on PVR, WOW, never knew you could do that. I need to see what other features are missing from my CDN version.
post #15773 of 16126
So my UN60ES8000 got stolen out of my house last week with a home break in, and I'm probably going to replace this TV with something different, maybe even plasma.
Not sure what brands or what right now, I just know that I'm going to rethink my original decision on this TV itself.
They didn't steal the EVO Kit remote or the TV Remote that came with it, nor the IR Blaster.
If anyone is looking for a back up to these devices, or wants extras, we can work out a deal, just PM me.
post #15774 of 16126
Wow that sucks. Did they actually take it off a wall mount or was it on a stand? Also, couldn't Samsung locate the set if the thief tried to use any of the smart features...I mean they probably wouldn't go into all that, they would just expect you to carry home insurance. But still if a cellphone has the technology to be located at a thief's address I'm sure a smart tv could be as well
Perhaps they will use the internet with the kit and the S-Recommend will suggest such shows as Law & Order and Cops...
Edited by gamermwm - 9/9/13 at 1:23pm
post #15775 of 16126
It was just on a stand here in the house. I don't know if the TV has GPS features in it? And they would have to connect it to the internet for anything else to work, so I doubt it can be tracked.
Its ok, I'm happy to go shopping again.
post #15776 of 16126
Yeah I don't think it has GPS but couldn't they see the serial number etc. if connected to the internet and track down the IP address and find where its located exactly? Anything that is connected to the internet can be located. And it doesn't hurt that the tv has a camera and facial recognition. Anyways, I'm just saying....I know Samsung is not likely to do anything of the sort...just thinking of possibilities
post #15777 of 16126
Sure, thats if they do connect it to the net. Seems like a big hassle to me though, calling Samsung etc. More work and headache for me.
post #15778 of 16126
post #15779 of 16126
Chris - major bummer. Sorry to hear about it.
But - shopping for a new one should be fun! I think Vizio has an 80" 3D, 240Hz with Internet apps. I got a promo on it the other day.
post #15780 of 16126
lol, I don't have room for 80", 65" is my limit, so I'm deciding tween the PN64F8500, or the Panny 65" ZT60
I really liked the LED, but after a bit, I was disappointed in the angle viewing and the IQ from that.
