Originally Posted by turboman123
hello eagle
Concerning the required backlight level, we also have to consider the peak white level. We can only compare the backlight level between Standard and Movie, if peak white level is the same. And the peak white level depends on the Contrast setting.
I use for Standard a contrast setting of 80, which is the Nitra setting. Originally I used a lower setting to prevent clipping, but clipping is still acceptable at 80 on my set.
For Movie mode, I use a Contrast setting of 100. Clipping is just visible, but still lower than Standard.
With those settings, both with a backlight setting of 6, I get following readings:
Peak white: Standard 153cd/m2 and Movie 146cd/m2 (small difference)
Black level: both Standard and Movie same level 0.08cd/m2
So my conclusion is that black level for Standard and Movie are aequivalent for the same peak white and clipping level.
See following measurement results. Also, white balance for Standard and Movie is more or less the same.
Standard-Movie.xls 100k .xls file
hello eagle
Movie is still a little blue by default, but still looks better than Standard by default. Standard is definitely more red on my set. The only way to improve it is lowering the contrast to around 82 as you have done, but this makes white more dull looking.
Once again, I just see no benefit of even trying to calibrate Standard when Movie even on default is better. Unless you just like a scorching picture. In that case, color accuracy really doesn't apply, so type of user would probably be better off leaving his contrast at 95-100 on Standard and then dealing with the overly red picture.
I guess I need to visit this thread a lot more.
