AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Samsung UNxxES8000 Owner's Thread
Official Samsung UNxxES8000 Owner's Thread - Page 221
post #6601 of 15499
Originally Posted by zotterr View Post
Hey Guys,I also owned a Samsung UE65ES8080#European Version)
The Banding is Horrible and i changed the TV 3Times. Are there any 65" Panels from Samsung without Banding?
Thx for Reply,
Roman
Get a vt50
post #6602 of 15499
Originally Posted by raven69david View Post
I hereby join the ES8000 crowd as i purchased my 55" set tonight since it was reduced to $2249.95 plus I received a free 32" free LED tv. I had been looking at this TV for months and was torn between this and the HX850. The 850 had been reduced to $1697.00 but could not pull the trigger. I'm a SONY guy and have been for years, but after the bad taste I received from an issue stemming with my 52 XBR4 a few months after purchasing it, this made the decision to go elsewhere quite easy. Plus this Samsung set gave me a better overall picture in HD and 3D then the 850 did while trying them out over the past 4 months. I've learned alot from reading this thread and will get my local Best Buy to do a professional calibration on the set before I can really see what it can do. But out of the box, OMFG it's awesome!!!! Can't wait for tomorrow to catch all the games with this awesome set. biggrin.gif
Congrats!! I feel I had the same story. I was going back and forth between those two TVs and I was a Sony TV guy too but had issues that were bad enough with my dealing with Sony that it left a bad taste in my mouth. The Samsung isn't perfect, but if you read the Sony threads, they aren't either. Good luck and welcome to the thread!
post #6603 of 15499
Originally Posted by dad0118 View Post
Get a vt50
Because plasmas don't have their own issues. smile.gif Dome people love plasma, some people love LCD. I can't do plasma. As for the 65" with terrible banding - very few are acceptable from what can be gathered here. Keep playing the panel library until you're happy or try a different maker. Son'y's 950, may be better with that, but then again, based on it's thread, it seems hit and miss too - and it costs more. If you can go with the 60", you'd be better off in this regard. If you can spend more money, consider and Elite or maybe Samsung's 9000, which seems to be better with banding. Or like Dad said, see how you feel about plasma.
post #6604 of 15499
Originally Posted by prsut View Post
Jestered:
I think during tour trip inside SM something altered your reference level of brightness. Where you have 74 value others have value at about 50. I believe CE dimming should start to be eliminated at 50 (brightness). This may cause blacks to be gray and for it you can alter RGB offset. As start point use difference between old brightness and new brightness.
Do not go too low with RGB offsets else you will ruin black levels at about 30% and you lose colors in dark scenes.
My current settings are brightness at 51, RGBoffset 18,20,19. If blacks are not deep enough, try dynamic contrast and or black tone - I know many of you (including me) are allergic to bother with dynamic contrast and black tone, but one can tray.
Other point of view is : raising brightness also raise contrast so you can dim picture. I am using backlight level at 3-4 (eco sensor) for night viewing and this compensates clouding to zereo while black details are good and white is enough to not to be fatigue and picture is not dull. Standard mode is probably not to be used for critical viewing and calibrating, but can be used to set "what you want to see"...
I tend to agree with this. I have my Brightness set at 53 with offset adjustments, and dimming is almost non-existent. It's definitely a a non issue now, and the little it may be doing on an almost totally black screen is not only acceptable, but nice in certain aspects. I have my ECO set to 5 and am considering 4. I feel ECO is key if you're watching in an environment that has a lot of light during the day and none at night - unless you're cool with manually changing your backlight twice a day.
post #6605 of 15499
Originally Posted by eagle_2 View Post
Everything you've mentioned here I found to be true over the last few days as I've tweaked settings, except the clouding issue.
Above 50 the CE-Dimming starts to go away for me. For me it took a setting of 62 to totally completely eliminate it to the point where I can see no trace of it during viewing. But I realize that's high. To compensate, I had to drop the offsets down very low. The benefit of this should of been that I can get away with a really low backlight setting, but with my backlight at 6 and a brightness of 62, my clouding is still way too easily seen now. To fight that, I found that dynamic contrast on low can help a bit, and bumping black tone up to darker helped the black levels also. Dynamic contrast on medium helps a bit more but now you're really starting to mess with the image in ways you probably don't want. I found having black tone on darker didn't really mess up my WOW settings, though in real viewing it does indeed affect the image quite a bit. I could try dropping the backlight a bit more, but honestly, I don't want to go too dim, as one of the benefits of an LCD over a plasma is a brighter image. As it is now movie seem just the right brightness and contrast. The image looks very good, I've got the color looking as good as I think I can get it probably, it's just that with these wacky settings, the black just isn't nearly black enough now, so the clouding is really visible. During credits now for instance you can really see how light the screen appears - it's like move mode, not deep black at all.
Eagle, if I remember right, you have your gamma up to +2. Now that you've made these changes, maybe try backing it down to 0?
post #6606 of 15499
I'm glad to see somebody else feels this way besides me. I think it's shameful what Samsung is passing off as quality for $2k - $3k sets. And yes, that's expensive.
Part of me totally agrees with you guys on this. But there is another issue that I try to keep in mind. Some people want a very thin TV with a very thin bezel. This tech is really at it's infancy. It's almost gotten ridiculous how thin these things are. I love it, but it's mind-boggling. But fitting everything into such a small, thin package costs money. Unfortunately, it also creates problems. I've read many times how such a small bezel introduces way more flashlighting, etc. There are trade offs on everything, but creating such a sleek TV costs more money than a thicker, less attractive TV - regardless of the issues introduced. That said, I still agree that it sucks having to spend that money on something with obvious issues. I didn't want an unattractive TV though.
Eagle, thanks a lot. Power is a wonderful thing. It was a very very weird feeling getting power. My wife and I literally haven't been that excited and happy since the birth of our last kid. We both felt that way, not kidding.
post #6607 of 15499
I used to have it at +2 but after using the WOW disc with the ce-dimming workaround, I brought the gamma back to 0 (it's in my settings from the last page).
post #6608 of 15499
I agree with you that these thin panels seem very attractive. Unfortunately it means picture quality sacrifices. My girlfriend's folks' Vizio is between 2-3 years old, and it is backlit, not form the sides. It's not even LED. Yet it's really not that thick. Not at all. Is the gain of shaving a few inches worth all the trouble with these screens? I mean compared to my old CRT, that Vizio is beautiful - it's like 85% thinner. Do we really need to have these screens as thin as paper? When does it stop? If they came out with a screen next year literally as thin as paper, but 30% more clouding and flashlighitng, would that be okay?
Just my thoughts on this obsession with this quest for the thinnest screen the manufacturers seem to be on.
post #6609 of 15499
Still on original firmware that my un60es8000 came with back in June.... 001013... There is NO WAY I am anywhere near to allowing an upgrade based on this thread yet. Not enough consistent feedback on pic quality, supported by any credible documentation by Samsung...Happrily staying put. I've mentioned that flashlighting is my only issue..yes it is, but its minimal and easily tolerated.
Zero banding vertical or horizontal in 2d or 3d
After this update, I may hold off too, but then again, I say that a lot. smile.gif
...am the geriatric poster child for old firmware on this thread as i sit on 001013??? smile.gif
Garnoch, glad to hear your power is restored. Wow, 11 days. I'm sorry.
ditto, i feel awful for you...power outtage is horrendous!!!!
Exactly. Avoid the Service Menu. It's poison.
...these scenarios are part of precisely why i gravitated away from overtweaking. It's not that I dont want to maximize the performance from my gear...but I've learned to appreciate my gear in a more tolerant way...make sense?
Get a vt50
......Sorry daddy, I did weeks of side-by-side comparison between led/plasma...then specifically narrowed down to Panny and Sammy.....Then even after my purchase i revisted this comparison. I used to say that Panny plasma was superior to Sammy for dark or almost dark environments but I retract that. IMH ( and well researched side by side drill) Opinion, I absolutely think that the Sammy can be tweaked to provide the better, more vivid and engaging picture even in the dark environments. Even though it's tricky on our pupils I have actually started watching more tv in the dark. I have not done that since the late 90's. When it comes to razor sharp detail and "live window effect" HD...the Sammy rules over all plasma.
post #6610 of 15499
Exactly. I don't know the answer. Too each their own I guess.
post #6611 of 15499
/quote]
Yes you are haha smile.gif Might as well though. And thanks, I still feel lucky though.
post #6612 of 15499
Above 50 the CE-Dimming starts to go away for me. For me it took a setting of 62 to totally completely eliminate it to the point where I can see no trace of it during viewing. But I realize that's high. To compensate, I had to drop the offsets down very low. The benefit of this should of been that I can get away with a really low backlight setting, but with my backlight at 6 and a brightness of 62, my clouding is still way too easily seen now. To fight that, I found that dynamic contrast on low can help a bit, and bumping black tone up helped the black levels also, though black tone definitely crushes black. I found having black tone on dark didn't really mess up my WOW settings, though in real viewing it does indeed affect the image. I could try dropping the backlight a bit more, but honestly, I don't want to go any dimmer, as one of the benefits of an LCD over a plasma is a brighter image. As it is now movies seem just the right brightness and contrast. The image looks very good, I've got the color looking as good as I think I can get it probably, it's just that with these wacky settings, the black just isn't black enough now, so the clouding is really visible. During credits now for instance you can really see how light the screen appears - it's like move mode, not deep black at all.
If somebody wants to take a crack at suggesting an improvement that might help, here's my standard settings:
Backlight - 6
Contrast - 96
Brightness - 62
Sharpness - 15
Color - 35-40
Tint - 50/50
Flesh Tone - +5
Gamma - 0
Dynamic Contrast - low
Black Tone - dark
Color Tone - standard
LED Motion Plus - off
Color Space - auto
Auto MOtion Plus - off/clear
White Balance
R-Offset - 3
G-Offset - 7
B-Offset - 7
R-Gain - 5
G-Gain - 25
B-Gain - 27
Eco is off - if I want the backlight lower I know how to do it.
Dropping brightness even just 2 points, from 62 to 60, helps quite a bit with black levels, though every point down from 62 makes the CE-Dimming more noticeable. Maybe on 60 it will be low enough that I may not notice it during regular viewing.
This may be a stupid question but has anyone tried to calibrate their set using Game mode? Obviously Game mode uses Standard mode by default and as I understand it, it has full calibration controls. I just wondered whether CE Dimming worked in the same way when Game mode is enabled?
post #6613 of 15499
Anyone still debating whether to pull trigger on the es8000 (not es7500 or any other than 8000 series), I say go for it unreservedly on any size up to and including 60".
My experience since May has been great. I am also sitting on fw 1013, have seen no need (yet) to update, and I and my wife love the pic quality. 3D has no banding or ghosting that I've seen. Calibrations: Using something close to Nitra's settings, after WOW disc. Started with the un55es8000, and upsized to the 60 simply to get bigger screen.
No significant/unliveable quality issues whatsoever on the set, minus minor flashlighting in corners. Not all that noticeable, truly. The WOW disc has a couple great tests to determine screen uniformity, dead pixels, etc, and fortunately our set has none of those negative issues.
It's been mentioned before, but perhaps there are indeed more significant diffs between PQ of the es7500 and the es8000? As I said, both my es8000s are terrific, so I'd recommnend not waiting till 2013 if you don't have to and get to unxxes8000 sets up to and including 60" size.
After 6 and a half months, count us very happy.
post #6614 of 15499
Congrats. I agree - up to the 60" and I have the 7500. The CE Dimming may react differently because of the 8000 having more Micro Dimming zones, but they look the same.
post #6615 of 15499
I haven't read hear of anyone doing that specifically but yes, Game mode will turn off all processing - like CE Dimming. I'd rather go back to Movie mode for that though - with the added calibration settings.
post #6616 of 15499
Just imagine what a bummer it would be for the consumer when we couldn't afford to consume this very TV because it would cost well over 5k$ to implement this "base level" of quality being bantered around here. I am all for our little panel lottery that simply requires the consumer to work hard at getting what they want. Expecting perfect the first time every time is prohibitively expensive and let's all keep our fingers crossed that no senior executive at any of the major electronics manufacturers decide this is the way to go. We will all be buying well built tanks that have double and triple backups and knock us all back a decade. Vive la loterie!
post #6617 of 15499
Jestered:
You're right and I mentioned that. What I did was use Samsungs built-in HDMI calibration tool to recalibrate my panel (in the SM). Doing this really darkened the screen, but when I calibrated the TV with those settings (there's 6 SM settings that changed) the picture is absolutely kick-ass! I've never been able to get my white levels dialed in correctly until now. Even though my brightness setting sounds high, you have to ignore the number. The actual brightness isn't that high, it's just the starting level is now much lower than with the standard SM settings. I messed with this a lot yesterday and was finally able to get my white levels dialed in, but I was going back and forth for so long that I didn't actually realize how much better it looked until I started watching football today. I can finally see details in the whites. For example, the Falcons white jerseys finally showed creases and I could easily and clearly see the mesh, which was usually crushed out with the standard SM settings. I'm loving this picture 100% now! So much so that I'm probably going to cancel the pro calibration appointment I have.
I'm more convinced than ever that Samsung changed the default SM settings to get the brightness down so the dimming feature would not be disabled. You can still get a great picture with those factory SM settings, but it's impossible to really dial it in. Using their calibration tool to set the SM settings allows you to get the white and black levels spot on and it really makes a big difference! A huge plus in that is the fact that I no longer have the bad dimming in my Standard mode because the brightness level is set high enough. And I didn't have to actually set the brightness too high to get rid of it. That high brightness setting is exactly where it should be because of the changes the HDMI calibration tool made.
If anyone is interested in what actually changed in my SM menu, here they are:
2nd_R_L
2nd_G_L
2nd_B_L
2nd_R_H
2nd_G_H
2nd_B_H
All of those SM settings changed significantly, which allowed me to finally dial in this picture about as good as I believe possible. It can look very good without the SM changes, but I don't think it's possible to really get it dialed in completely without those things changing. I've never been happier with the PQ than I am now. It's the first time that I've felt like I no longer need to mess with the settings to try to improve anything. It's perfect at this point.
post #6618 of 15499
Actually I did use the WOW disc the other night on game mode. My settings for game mode turned out to be identical in every respect due to it being based on standard mode. There seemed to be no benefit to me using game mode over standard since the settings end up being the same. Garnoch had mentioned that CE-Dimming doesn't affect game mode. Unfortunately I can confirm that CE-Dimming does affect game mode just like standard mode. My girlfriend could see it easily when I demonstrated it earlier. Leaving the menu up on screen is an easy way to observe the level of CE-Dimming - if any auto-dimming is happening you can instantly see the menu dim with the rest of the picture, and it does auto-dim in game mode. Just like in standard mode, a high brightness setting can disable the ce-dimming.
Plus, you lose some options, like auto motion plus is disabled. So there seems to be no point in using game mode, other than of course for gaming, which definitely is a plus because there is certainly less lag in game mode.
Edited by eagle_2 - 11/11/12 at 4:55pm
post #6619 of 15499
Sorry but that's nonsense. People are spending close to $3k on some of these sets. You don't think that deserves some quality control? They must love customers like you. There is absolutely no reason to expect prices on a tv set to double or triple in price just to have some level of quality control on their panels. That's just baloney! According to Cnet, they were very impressed with the uniformity of the Panasonics (they didn't like much else about them, but if they can make panels with good uniformity, then there is no reason why Samsung shouldn't be able to also). And my girlfriend's folks' $450 Vizio from 3 years ago has NO CLOUDING OR FLASHLIGHTING WHATSOEVER. So that is just plain nonsense. I can't believe that some people actually think the panel lottery is a good thing for anybody. It's bad for the consumer and bad for the company too. Anybody that thinks otherwise has no idea what they are talking about.
Yeah, let's not hope the execs read this and decide to give us quality. rolleyes.gif
Edited by eagle_2 - 11/11/12 at 4:43pm
post #6620 of 15499
Actually I did use the WOW disc the other night on game mode. My settings for game mode turned out to be identical in every respect due to it being based on standard mode. There seemed to be no benefit to me using game mode over standard since the settings end up being the same. CE-Dimming also affects game mode just like standard mode, plus you lose some options, like auto motion plus is disabled.
Cheers for the replies guys. Garnoch, I initially too thought Game mode did disable the CE Dimming but I established, as eagle_2 rightly says, that it doesn't unfortunately. So as you've both stated, there's not really a need to use it other than for it's true purpose, gaming.
post #6621 of 15499
@Paulybaby77,
Yeah, I added a bit more to my post after I read Garnoch's comment, just to clarify and add a bit more explanation regarding game mode and ce-dimming.
post #6622 of 15499
CE DIMMING IS ON IN GAME MODE???? That's freaking crazy. The point of game mode is to have all than nonsense turned off for least amount of lag. My bad but that's odd. Thanks for the clarification.
Does it stand to reason then that game mode while using Movie would have less lag?
Edited by Garnoch - 11/11/12 at 5:29pm
post #6623 of 15499
I agree it sucks that quality control isn't what it should be and that the panel lottery stinks. If one panel can be good, why can't they all be? I'm just not positive they can do it with a TV with such a small relative footprint without it costing them much more - which would then be passed onto the customer. I don't know. It sucks though. I'll tell you this.... I would pay more to be guaranteed to get this TV with a perfect panel. Regardless, I think if people want to talk or complain about this and other issues, this is the perfect place - assuming you own the TV.
post #6624 of 15499
The second problem sounds to me like standard compression from cable/satellite tv. You will especially notice this during fast motion, and also sometimes bright flashes, depending on the channel and the amount of compression applied. The image will break apart into a mosaic pattern like you described - macroblocking. Usually some or all channels are compressed which causes these very noticeable compression artifacts.
Thanks for the info Eagle, Garnoch, and GTM73. I'm thinking you are probably right about it being a compression issue. I've only seen it on live TV. Just FYI -- I'm running a DirecTV HR21-700 box through a Marantz SR5007 with no video processing as I understand it (output resolution is set to "auto" on the AVR). Everything goes through the AVR to the TV through one HDMI cable from the AVR.
Any thoughts on why the "Update Firmware Available" box keeps popping up every time I turn on the TV and is nonresponsive? Very, very annoying! Am I the only one with this issue?
post #6625 of 15499
Nope, won't help in the slightest, because if you enable game mode while in movie mode, it just reverts to the same game mode based off of standard. Try it. From standard mode, go into game mode and set it up as you wish. Now leave game mode, and go into movie mode. Now go back into game mode from movie mode. It's the same exact game mode you were just in, with all the same exact settings, based off standard mode.
Bottom line: there's only 1 game mode, so no matter if you are in standard or movie or natural or dynamic, game mode is game mode - it's all the same mode - with CE-Dimming.
And yeah, I agree, it's ridiculous. The whole point of game mode is to disable all unneeded processing to improve lag. So then why is ce-dimming active? I bet I can answer that: because Samsung knows that they have major uniformity issues with their screens, and game mode doesn't change that. So they are willing to hurt our game lag in game mode by forcing ce-dimming, just to help hide the uniformity issues.
post #6626 of 15499
Not sure about that one. I really can't imagine why the update box would keep popping up like that and freezing. Very odd.
post #6627 of 15499
I see no reason why it would cost that much more to improve the quality control of the panels themselves. Everything else is fine - it's the panels that have the issue, so that's really the only are that needs to have extra attention devoted to it (and better firmware but that shouldn't cost any more money - just better people making the decisions). It certainly wouldn't double or triple the cost of the entire set. If the cost of each set went up a couple hundred dollars next year, but that meant instead of 10% of the panels being close to clouding/flashlighting free, 80-90% of them could be, I think that would be a good situation for everybody. A bit more cost for us, with the benefit of stepped-up quality control on their panels, so the odds are very very high in getting a great screen, instead of how it is now, with the odds very very high you're going to not get a good screen. And many many less returns for the company, since uniformity issue related returns would be greatly reduced. The reduced returns could also mean better return policies by stores, and maybe better sales or discounts, since the stores won't be getting hit so hard by returns, again due to uniformity issues. It would be a win-win situation for all of us.
post #6628 of 15499
Eagle, the market works. If the $450 Vizio from 3 years ago was all that great no one would be shelling out "2-3k$" for the ES8000 (or the ES7500 or ES7100 etc etc). If uniformity were the ONLY consideration when purchasing a television, and IF the ES8000 suffered from poor uniformity, and IF the panasonics (assume you are referencing the VT50) had GREAT uniformity, well guess what no one would buy the ES8000. Of course if ifs and buts were candy and nuts we would all have a Merry Christmas. That example is simply specious, at best.
The point simply being 3k$ in the realm of the world doesn't buy you very much. It buys a family a flight on a vacation...But the plane might leave on time, or it might not. It buys you a used car, but you may or may not have to fix a fan on it. It certainly won't and shouldn't buy a cutting edge television that works flawlessly out of the box, the first time, everytime.
The panel lottery keeps prices at the point where you and I can afford to buy this set. If your wishes and dreams for quality came true I would not be buying this TV. Maybe you would but I don't see why you would want to dispense with twice as much of your disposable income. Isn't it far better to have financial access to this technology and on the very off chance that the panel doesn't work out that you just chase down the service side of the company and try, try, try again until you get one that suits your needs?
post #6629 of 15499
Garnoch, how much extra do you think it would cost for Samsung, or any other panel manufacturer, to GUARANTEE the panel was flawless?
Going a step further, what exactly is a guarantee? Would the company be pledging to give an unfortunate recipient of a non-flawless panel a million dollars? Or would they, perhaps, just be prepared to replace the set? Oh wait, that is what they already do... I guess we all have the guarantee we need!
post #6630 of 15499
Again, the market works. These folks are clearly optimizing the R&D and production cost vs reputation and trade in cost ratio. If it was possible to produce more "quality" sets in a fashion that optimized the cost, price, sales volume, return cost, reputation/brand impact rest assured it would be happening.
What really matters is if your panel isn't up to snuff that you can return it. You certainly can, and should.
Be prepared for disappointment going forward. Little works the way it "should". No one is entitled to that just for tossing around 3 grand.
