i have an 8yr old sony receiver, so no hdmi, but it's still working fine. i used the toslink from the tv out to my receiver, it does output audio, but only 2 channels like others have mentioned. i also have an old sony bluray player, last that i know of it does have some apps, so i guess i will try to update it and see if AIV and netflix will be there. since it seems clear that sammy devices only output 2 channel audio from their smarthub apps, then i'll just get another brand of bluray player. it really doesn't make much sense to have this kinda limitation, so my money goes to somebody else.Originally Posted by Ricoflashback
If your Bluray player is connected to a receiver that is capable of processing 5.1, DTS or even 7.1 channels - - you will get the full soundtrack.
Obviously, if you're playing your audio through your TV or a soundbar - - you will not get the full soundtrack and the audio will be matrixed to the highest level your audio supports.
I can confirm that OTA (Antenna Broadcasts) send out a 5.1 signal to my receiver via optical link. I have not streamed anything from the TV (Smart Apps.) since I stream everything through my Sony BDP S-790 Bluray player - - which passes full Dolby Digital and more when I stream from Amazon Prime to my TV via the receiver.
Quick question - - what is your home theater setup?
Just kidding.
