AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Samsung UNxxES8000 Owner's Thread
Official Samsung UNxxES8000 Owner's Thread - Page 230
post #6871 of 15313
Originally Posted by Garnoch View Post
FIRMWARE UPDATE 1041.1
With power restored after 11 days, I couldn't wait to watch my TV and decided to update the firmware so I could report back. My daughter was watching something and it didn't look quite right. Then my wife and I sat down to catch up on Survivor, which is beautifully shot. I could tell things were just not right. This is the first time that I had a negative feeling towards an update so I stayed up after my wife went to bed and broke out the WOW BD and AVS files. I wish I had meters and equipment, but oh well. So I was right that a couple things were obviously off which surprised me, because that hasn't been the case yet for me with updates. So far for me, updates have either looked the same or possibly a little better, but never has been cause for me to change settings. In both Standard and Movie modes, I had to change Contrast and Gamma. In both Movie and Standard I had to drop Contrast by one point (maybe could have gone two but didn't need to) and raise Gamma one point to 0, even with the Brightness trick to diminish CE Dimming, which I raised 2 points to 0 (which makes me feel I could have balanced it by raising Gamma by 1 point and raising Brightness a little, but that didn't feel right). I also felt I had to then lower my backlight, especially in a dark room, so I lowered my ECO by 1. Anyway, I'm back to having an awesome picture and I've updated my settings post based on this firmware update. Good luck everyone!
I want to ask, how did you get the update 1041.1 installed? My TV states 1041 but the web page states 1041.1 is available by USB. In doing a live chat with samsung they stated they are the same. I have tryed placing the update on the USB, in zipped format, unzipped in the same folder name, in the "image" folder and even not in a folder and the TV just wont take it... what worked for you?
post #6872 of 15313
Originally Posted by skibum5000 View Post
Can the CE Dimming be 100% turned off on this set? I know that it could on the old B series but not on the C series. So how about on the ES?
And can the micro dimming stuff be turned off on this 8000 if you don't like it? (these features also would seem to make calibration for gamma a bit trickier, although if you manage to keep a bright white window on part of the screen you can get a fair measurement of black level and low gray at least on the non-micro dimming sets)
If all the dimming stuff can be turned off on all the sets how do black levels compare on this compared to a sony hx850 or 929?
does the edge lighting cause dark screens to have faded gray extending down from the edges as the early edge LED lit screens had when the dimming and autobacklight dim and such were turned off?
Does the 8000 have the weird thing where even and odd scanlines have a slightly different luminance for one of the green sub-pixels that cause a solid block of yellow and orange and certain blues, in particular to render odd and even lines as slightly different colors (!) giving them a slightly nasty striped effect that I first noticed in many of the C-series screens (although not so much on the very highest end model C series) and even more of the D series screens? I can't believe that more people never brought up this issue (I did see a few others though). In the PC monitor world people would have gone crazy over such a thing.
thanks.
The CE-Dimming cannot be turned off. That's one of my biggest problems with this set. The CE-Dimming makes even trying to use the Disney WOW disc very difficult because of the dimming effect. There is a workaround that has been discussed quite a bit over the last few weeks, but it isn't ideal - it involves raising the brightness considerably which lessens the CE-Dimming effect - the higher the brightness, the less the CE-Dimming kicks in. You then bring down the white balance offsets to compensate for the increased brightness. Unfortunately that does odd things with the blacks so it isn't ideal.
I'll let somebody else comment on the rest of the questions because I'm not familiar with the issues you are asking about.
post #6873 of 15313
Originally Posted by darkvader001 View Post
Hi, i have the same problem after the 1041 update. Do you mind to share your Dynamic and Standard mode modified settings?
Some people here might have laughed that you asked me for Dynamic setting because I know I did - I'll only give you my settings if you promise not to use Dynamic. smile.gif
I'm kidding but you can find my original Movie and Standard settings along with my settings for reducing CE Dimming on page 117 or by clicking the direct link you see when you go to my profile by clicking on my name. Good luck!
post #6874 of 15313
It's the same update. You're right that your TV shows simply 1041, but if you go to the contact samsung menu, it will show you the entire number.
post #6875 of 15313
thanks.
Like Eagle said, those can't be turned on or off, but... Movie mode does not have either, so in essence, you can have them off.
I'm not sure about the 850 or 929, but the 950 seems very very very close to the 929 and after reading that thread and seeing comparisons of people who have had both, I would say the 950's black are better with the 8000 in Movie mode, but then again, the 950 has it's own processing going on too.
The last issue you bring up I've not only never seen but it's never been talked about on any page in this thread, so I think it's a safe bet that this isn't an issue with the ES.
post #6876 of 15313
LOL I figure that was going to happen, but the reason why I asked is because my wife like Dynamic more than the Movie or Standard picture (lest be honest, the Movie and Standard settings don't always show crisp eye popping colors and some people prefer that).
I try your Movie and Standard settings but colors don't POP like the use to before the damn 1041 firmware update.
My dilemma is that before the 1041 my modified Dynamic with Backlight = 11, Contrast = 96, Brightness = 46 and Eco Solution = ON (minimum backlight set to 9) looked incredible, and when I say incredible I mean crisp define AWESOME picture. But after the update programs and movies that before showed amazing eye popping colors now doesn't :-(. Colors now look dull and I have try everything with no luck.
Can someone confirm that is actual problem with 1041 firmware is that the colors now show dull, anyone that have experience the same? Is like something that Samsung changed now is not right. One thing I notice after the firmware upgrade is that there is a lot more light being push from the edges, you can see this on a totally dark room. Before I can barely see light coming from the four TV sides and being push toward the center, now is like the TV backlight is a lot stronger and can't go down to darker mode wish maybe is causing what I see as wash out dull colors.
Any help, ides or suggestion will be greatly appreciated.
I want to try the dynamic settings you have now, if you have modified them from the default once after the update to see if I can get it to work like it was for my wife.
I have my UN65ES8000 since June, I have been extremely happy with the picture, but now to me is just not looking the same as before, even 3D don't look as crisp or define as before.
post #6877 of 15313
Try a full reset - - make sure to copy down your settings. I experienced the same thing with an earlier firmware update the the reset brought the picture back to life. I do not use the Eco Solution - period. I'm also in a dark, man cave in the basement with backlight at 12, contrast at 90 - - Standard mode. Everything pops for me at this setting. (My brightness is set to 40 with sharpness at 35). There are a lot of suggestions - - very good ones from Garnoch and others like Nitra (where in the world is Nitra today??) on tweaking your set on this thread.
So - full reset should solve your problem - - it did for me. Best of luck. (Full reset via main menu - - not "picture" reset.)
Happy Thanksgiving everyone!!!
post #6878 of 15313
Hi,
Thanks for your suggestion, I did a full reset after the update a couple of days ago and did't notice any improvements, but I will try again and see.
I'm not in a man cave, I have the TV on the living room which gets a decent amount of light during the day, at night is when I can get the living room close to full dark, but before the update the Eco Solution was working great for me, not issues at all before this mess up update. But I will try your suggestion.
Is hard to explain but is like objects are not as define as before on colors just don't pop :-(, even the view able angle have drastically suffer, before I was able to sit on an angle and don't loss color crispness, but now is like a smoke cloud is on top of the picture.
I wish there was a way to downgrade the firmware.
Edited by darkvader001 - 11/21/12 at 8:50am
post #6879 of 15313
If you're already using the settings I have posted, just double check them, because I changed and updated them based on 1041. As for Dynamic, I honestly don't have settings for it, sorry. I do agree though, that even with updating my settings based on WOW disc and AVS files, I feel it's not quite as good as it was before the update. I could be reading too much into it though, hard to say.
post #6880 of 15313
Nitra is just very very busy at the moment. He'll be back.
post #6881 of 15313
darkvader, you might have indicated this already and I just missed it, but is your set a 7500 or 8000?
post #6882 of 15313
TV = UN65ES8000
Panel = AH01
post #6883 of 15313
I don't think you are reading too much into it, is really different. Have you notice a difference when watching the TV on an angle? For example, before the update I was able to watch the TV on an angle and the colors where almost 99 % identical as being in the center. Now the colors get very wash out with the smoke curtain effect
I will reset the TV and re-enter the settings again and see what happen.
post #6884 of 15313
Just an FYI - - I had the same issue and it took 24 hours for the picture to come back to where it was before - - with a little tweaking. That's why I initially resisted firmware updates but also want to make sure that if there is an improvement in dimming or feature that I can use, that I'm able to take advantage of that.
Also - - when I update now, I have everything off - - in terms of STB (Directv) and set the source to my TV antenna and perform the update that way. Maybe it doesn't make any difference, but I'm trying to eliminate any hiccups with the firmware update. I know it's frustrating but your picture will come back - - trust me. Either with the full reset or a future firmware update. And I know exactly what you are talking about - - I had a firmware update that just clouded everything - - it looked like a film on the picture - - it was a total change from my previous settings.
post #6885 of 15313
I haven't noticed any difference on off angle, but I do notice the most difference on regular TV viewing. Speaking of angle though, I did have to lower my contracts because of this update, you may want to do the same.
post #6886 of 15313
Originally Posted by Mavinwow View Post
Can you guys help me understand something regarding black input. My understanding of PS3 color output, is that limited is 16-235 for black, and full is 0 to 255. This is an output setting on the PS3.
Now, there appears to be a corresponding setting on the Samsung TV, HDMI Black level. Where low is 16-235 and normal is 0-255. However, this option always seems greyed out. I switched my PS3 output to limited which has fixed some crushed blacks I was getting in games, but my TV is greyed out and set to normal still. Am I not understanding this setting correctly?
bump
post #6887 of 15313
I agree dynamic really improves the fly screen affect and clears the air sort a speek. the only issue is the black shades get lost. Ive calibrated standard with my wow disk and now I think this weekend im going to ticker with dynamic to see if i can find a good medium. I'll also try to get around to posting some pictures of different souces and modes. I went to best buy last weekend and the es on display there is mesmorizingly beautiful, not sure if it's because it's blownout settings or the backlight is maxed out but i asked if i could fiddle with the remote and they gave me the sensor remote with the thumb tracker on it, i tried to navigate to the setting but but got frustrated and gave up. freakin hate that stupid thing.
post #6888 of 15313
I can't fully help you but I assume you're connected via HDMI. If Nitra was here, he could answer that one. If you find his settings post, he has a note about it at the bottom. Mine is greyed out on some HDMI inputs too but look correct. If it's not correct, the picture will look very washed out. I had this issue with my DirecTV HR24 DVR but was able to change the setting, which fixed the issue. If you don't notice it being obviously washed out, my guess is it's on the correct setting.
post #6889 of 15313
Thanks for the reply! I have read his comment, and it seems like I should be able to control the HDMI black, but it is always greyed out.
I am connected to HDMI 2 on my TV, with all my HDMI sources being switched by my receiver.
post #6890 of 15313
So CE Dimming is really truly 100% off in Movie mode? Because I know people had said that about the C series but my 55C650 absolutely did the CE dimming thing even in Movie mode no matter what I set. It wasn't a huge effect but if you tried to measure black point on a largely all black screen or even a few shades up from that the set absolutely dimmed down and it did toss setting up gamma and gave people those fake super high 5000:1 contrast ratio measurements and such. So it is not just lessened but 100% truly gone in Movie mode? (Movie mode is the only one I ever use on Samsungs anyway so that would be good.) On the ES7100 thread someone said that CE dimming is still on even in Movie mode but that micro dimming is turned off there (but on in all other modes). ?
And do you know if the Sony sets also do CE dimming type stuff and if it can be turned off?
And can the local dimming features be turned off on all of these sets?
Hopefully none of these have that striping effect (put up bright yellow orange or certain blues and look closely and instead of 100% solid smooth color it looks like tiny 1/3 scanline height lines that are slightly darker running horizontally across the screen, for some reason few people brought it up for the C and D series even though many, many of those sets had it (it did depend a bit on which panel you got, the SQ actually were the most guaranteed to have it other than for some reason in their top # model where I never saw it even with the SQ, I originally thought it was a manufacturing defect in their new LCD production line but since the D series had it to I was no longer sure what to say. It is not just me because some other people did, independently, point it out too.) Looking in the store it seemed like the ES yellows might be free of it, I was a touch worried that I might have seen in a few dark sky blues, not sure since those scenes went by so fast. I was a touch worried I might have caught a bit of it in Sony 850 yellows but I need to get a better. It was pretty bad on many C and especially D series sets though.
Edited by skibum5000 - 11/21/12 at 12:04pm
post #6891 of 15313
YES, I didn't see Transformers in 3D but Hugo, The Avengers, UP, Prometheus, Avatar..... Loved those in 3D.
Ah Blazing Saddles, It's been too long, must watch that again being I have it smile.gif
"WHERE DA WHITE WOMEN AT?"
"Is it twue what they say about your kind?"
post #6892 of 15313
AH, that's the answer. You're receiver is doing the work for you or at least the TV thinks it is. It's only greyed out when the TV doesn't think it's needed to my knowledge. If the picture is washed out, connect that direct to the TV and let us know.
post #6893 of 15313
No one here has mentioned the striping and I've never seen it either. It appears CE and MD are totally off in Movie mode. I believe you can see it greyed out in the service menu with no way to turn it on. That being said there is a Black Enhancer option that if turned on seems to have a slight CE effect. I can't talk about the Sony's though.
post #6894 of 15313
I watched it again about 2 years ago for the first time in a long time and my jaw dropped all through the movie. Crazy. Great movie.
post #6895 of 15313
There doesn't seem to be any sign of CE-Dimming in movie mode. However, micro-dimming is also turned off in movie mode, which is unfortunate. Micro-dimming is supposedly a big feature of this year's sets but but they don't mention is it is unavailable in movie mode. It is different than CE-Dimming and is supposed to be a good thing.
post #6896 of 15313
So I got an automated call today from Samsung saying that it was a follow-up to my service call yesterday, and that according to the records, the problem has been resolved!! If yes, press 1, if not press 2. 2
Seriously? So I pressed 2 and and then the voice said I should get a call within 1 day (which means Monday of course due to the holiday). Confused I called the repair facility that sent the tech down yesterday, and they claimed to know nothing about anything. They said the tech didn't add any additional notes to the work order. I asked them why the tech said Samsung will decide what to do about the panel when isn't it the tech who should decide since he was the one who looked at the panel? They didn't have any answers for me and said they will call back today. They never did call back. So I have no idea what is going on at this point. I told the guy on the phone that the tech spent less than 10 minutes at my apartment and didn't even write down anything about the banding I was having in 3D mode, saying it was "all due to the backlighting". All the tech wrote on the slip was "Flashlight effect/backlight bleed".
In other news:
http://finance.yahoo.com/blogs/breakout/does-best-buy-chance-survival-130251676.html
"Best Buy On Life Support: How Showrooming Can Save the Chain"..."If Best Buy wants to be alive next year it needs to stop running from its history."
post #6897 of 15313
In other news:
Eagle_2 - sorry you're having this experience with an authorized Samsung Repair facility. Quite frankly, it doesn't make sense. My local company was great - - I sent him a picture of my panel with the vertical banding and he recognized it right away. And...ordered a panel.
If the repair shop is in business to make repairs (duh?) it would seem logical that they would want to fix your TV. Can you call the owner of the repair shop? Look up the company in the BBB and you should find the owner. Again - - this makes no sense. They do not get any $$$ for repairing your TV and Samsung loses a customer. WTF??
post #6898 of 15313
OK, thanks.
Apparently the SONYs have it (ce dimming type stuff) and it may be even more persistent on the 850 and even the top 850 and 929/950 don't have a full CMS or 10pt calibration and supposedly they make bright greens too neon in any mode because of that.
post #6899 of 15313
I forgot about the lack of calibration on the Sonys That would drive me nuts.
Eagle, sorry, man - be persistent.
post #6900 of 15313
So what are the actual, real differences between the ES7500 and ES8000?
One review sight in the UK seemed to think something about the ES7100 made it handle motion at times worse than the ES8000 although maybe it was just down to the firmware on each at the time (seems like ES7100 has had more firmware issues?). But I haven't found much solid about ES7500 vs ES8000. Better panels reserved to be always used in the 8000??? Anything at all other than micro dimming ultra (which is off in movie mode anyway) and the set styling? Panel uniformity, backlight bleed differences on average? Same exact panels used??
