Originally Posted by Riftburn
Thanks for the reply! Currently I have HDMI Black level on the TV set to normal. Also on the ps3 the RGB full range hdmi is set to limited. When set like this it looks like the brightness is too hight, that's the best way I can describe it.
However if I set the HDMI Black level to low on the TV it looks fine. For instance I'm watching The Last Crusade right now with HDMI Black level set to normal on the set, and RGB full range HDMI set to limited on the PS3 and it looks amazing. What im puzzled about is that I dont have to do this with any other movie I have so far. Is there a reason for this or maybe a setting I'm overlooking entirely?
Thanks again for the help!
I think that although you feel the other movies are okay, they actually need it too. If you're seeing somewhat washed out pictures, I'm pretty sure the correct setting for HDMI Black Level in you setup is Low, otherwise chances are that HDMI Black Level would be greyed out, defaulted to Normal. Can something be changed on the PS3 instead? I don't know.
