AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Samsung UNxxES8000 Owner's Thread
Official Samsung UNxxES8000 Owner's Thread - Page 306
post #9151 of 15313
Happy New Year, you guys!
post #9152 of 15313
Thx, happy new year to everyone!
post #9153 of 15313
< Duplicate >
post #9154 of 15313
Happy New Year to all of us.
post #9155 of 15313
Originally Posted by mo949 View Post
If you got it bad you'll see it during normal viewing from all sources at all angles. If you can't see it at all during normal viewing then I'd agree with you on the paranoid bit smile.gif
Thanks,That is what i need to hear
I did the same thing with my Samsung Plasma(worried about the buzzing) for the first few weeks, absolutely love the tv now.
post #9156 of 15313
Happy New Year to the es8000 club. My tv did a boatload of heavy lifting last night and delivered a knockout with ondemand MenInBlack3, bluray DarkKnightRises and bluray Imax SpaceStation3d....not too mention the ribeye steaks, yeunglings and shrimps....
post #9157 of 15313
post #9158 of 15313
Garnoch, I still have case, c'mon over....we'll get smashed and watch some football or movies!!!
post #9159 of 15313
I can be there by tonight haha. I prefer their straight up lager but they have the best light lager on the planet. Here's a nice one to try though - half lager light and half black & tan. smile.gif It pairs well with football on a Samsung ES.
post #9160 of 15313
Ha ha....i've got the black n tan and the lite....sonwe are in business!!!! Hey boss, what and why do you the diff between standard and movie. Seems to me I found the best overall day and night by going std, 49-50 color, color space native....great saturation, blacks and almost zero flashlight. Unless on superdark contrasty material, this seems to be killer. What benefits do you think I may be missing NOT being in movie mode?
post #9161 of 15313
Has anyone of you experienced the smart hub turning on by itself while watching tv? It happened to me a couple of times. It flashes then disappears. Sometimes it stays on. I'm curious how I can turn that off or prevent it from happening.
post #9162 of 15313
known issue, flashes for 0.2 seconds then goes away for me.
post #9163 of 15313
This is an on-going major issue.. Smart hub flashes up within 3-minutes of power up. Samsung has yet to release a working fix. If you call support they will tell you to reset smart hub and it will delete all your apps and not address the issue, then they will set up a service appointment where a tech will come out and do nothing but contact samsung just to be informed of a future unknown smart hub update fix.
I suggest "everyone" post your concerns here for samsung reps to see and reply;
http://forums.cnet.com/7723-13973_102-580089/smart-hub-glitch/?refresh=1356613666678
Edited by badabing - 1/1/13 at 10:55am
post #9164 of 15313
Nope, I do all streaming from smarthub on my e6500 bluray player...
post #9165 of 15313
Accuracy in the picture on the screen. ( color, shadow detail, skin tones etc)
Edited by Bolt989 - 1/1/13 at 12:31pm
post #9166 of 15313
Okay Bolt, be specific please.
post #9167 of 15313
Bolt, I actually mean to have you elaborate in specific detail. Please proceed...
post #9168 of 15313
post #9169 of 15313
Nice! We're all set then!
I have listed a Movie mode that I love and two Standard modes. The first Standard mode I have listed doesn't diminish CE Dimming though so I don't use it, but like you, I do use Standard mode (the one diminishing CE Dimming), without Dynamic Contrast turned on. Movie mode is easier to "calibrate" and because of the lack of Micro Dimming and more calibration options, does have better/truer colors, but I got Standard colors to almost perfectly match my Movie colors. Because of that, I'm in Standard, taking advantage of MD to give me better blacks/less clouding. I do go back and forth though.
post #9170 of 15313
Funny enough ever since disabled wifi on the tv the smart hub bug has gone away. I wonder if its that simple....
post #9171 of 15313
Also try Turboman123 settings - AVS Samsung Forum (Page 267 - Post#8007) - and the BT1886 "Gamma" settings (short for "Black" & "Tan.") smile.gif
Edited by Ricoflashback - 1/1/13 at 2:31pm
post #9172 of 15313
Rico & Garnosh / Opsguy * Sabesh = AVS RockStarzzzz....
post #9173 of 15313
I probably should. I've tried a lot of setting before settling on mine, and the best color and white balance settings for me were the CNET Movie mode settings for the 55" ES. Being Turbo and you you both have 65" TVs, it didn't surprise me that you thought his worked best on yours. Even then, I'm sure there are some differences between his and yours. I've just been so happy since tweaking my settings that I haven't bothered trying any others. I am curious though. If the next FW update doesn't fix my Eco sensor issue, my next step will be a full reset, at which point, maybe I'll try Turbo's before putting mine back in. I have a feeling his settings will work better for you than they do me on the 60" though. I was going to get involved with borrowing Turbos equipment, but I'm an all Mac house and can't run his software. That being said, I bet the BT Gamma settings are awesome. smile.gif
Edited by Garnoch - 1/1/13 at 5:21pm
post #9174 of 15313
Too modest Blade for not including yourself
post #9175 of 15313
Each set is different. The only way to get a proper calibration is to have it pro calibrated with equipment. Using someone else's settings is silly and may even do more worse than good. Using someone else's calibrated settings is far from accurate.
Using someone else's 10p white balance is the worse. With that your really messing up the image, even if u think it looks good, its not and can get much much better from a actual pro calibration. For those who want accuracy (think movie theater color)
post #9176 of 15313
Total B.S. - forget "accuracy," this issue is how the TV looks for you and the best performance you can get. FYI - I cross checked Turboman123 settings against the Disney WOW disc and did not need to make any adjustments - - they were spot on.
And there is no point in this forum if we can't exchange ideas and settings -- unless folks want to hear you extol the praises of Plasma technology and rip the Sammy sets. Oh, that's right, you have one now.
post #9177 of 15313
A meter is the only way to get 100% accurate color/10p white balance, period. This is 100% factual. Using someone else's 10p white balance is pointless and more than likely doing mote worse than good. I like to have that "movie theater" type experience when I watch movies. I calibrated my own es8000 using my equipment and I dont share settings because like I have said its useless.
The point is, it can get a lot better with a pro calibration.
Edited by Bolt989 - 1/1/13 at 3:54pm
post #9178 of 15313
Will have to check that out... Thanks. You may want to post your find over at the cnet samsung forum where someone from samsung will see this information. Who knows, it could help lead to a working fix;
Edited by badabing - 1/1/13 at 4:24pm
post #9179 of 15313
I know this is a dumb question, but what does the 1920 x 1080/ 60i or 60p mean?
Well the 60i/60p that I see, what does that mean specifically? Is that a good number to have there or should it be higher/lower?
I'm seeing this when I switch from my UVerse box to my XBox.
Also, my TV has been up for a few days now, not watched a BluRay yet, but the AT&T UVerse picture is a bit disappointing, is that just based on the nature of this service and box?
post #9180 of 15313
hear, hear
