AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Denon 788
Denon 788
post #1 of 7
My Denon 788 has started to power off and go into standby mode,it will reset in a few minutes but its started to happen alot lately.Anyone have info on this problem?
post #2 of 7
The most common reason is a speaker wire from one post touching another post causing a short so pull out the AVR and visually check the rear panel speaker wire connections, otherwise it may be amp failure.
post #3 of 7
Wires look ok......What is the reset for this Avr?
post #4 of 7
Should be listed in the back of your Owner's manual.
post #5 of 7
2 factory resets and it still kicks on standby......guess its fried.....No more Denon for me.
post #6 of 7
My buddy's Pioneer vsx-1014 wont reset anymore either, he's had it for 6 years or more. you're gonna get defective equipment eventually no matter what brand you buy.
Did you try unplugging all the speaker wires completely? How long will the receiver stay on that way?
post #7 of 7
I reset and reconnected speaker wires and it will last about 20 minutes.
