AVS › AVS Forum › Audio › Home Theater In A Box › AVR bitstreaming not working
post #1 of 2
Sup all, just got an Onkyo 6300 and set it all up nicely. I was hoping for some plug & play magic to happen once I hooked the HDMI to the 6970 but nope, that'd just be too easy. Apparently you only have to select this and your good to go, except for the part where for me it just says that it's not plugged in.
Catalyst center shows the receiver as a display and for what it's worth shows there is a connection made. I don't know what to make of it since this is my first time with surround, my HDTV is hooked via a DVI/HDMI if that could lead to a problem.
I really have no idea what software or settings need to be changed. I'd greatly appreciate any help you give so I can watch and play stuff in 7.1.
post #2 of 2
Catalyst? That means you're using a PC with AMD/ATI video card. You may get more help in the HTPC forum where they should be more familiar with your problem.
http://www.avsforum.com/avs-vb/forumdisplay.php?f=26
  Back to Forum: Home Theater In A Box
