AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › Update for the epson tw9000(5010) is ready
Update for the epson tw9000(5010) is ready - Page 10
post #271 of 430
I upgraded my firmmware from 100 to 104 a few months ago, and I also noticed the 3D actually seemed to get jerkier than it was before the upgrade. I did figure out that if you have any of the sharpness settings turned up from the default settings at all, it makes the jerkiness worse - if I put the settings back to default, the jerkiness isn't nearly as bad... I setup a memory setting for mostly factory default settings, I always set the memory for that before I play a 3D movie.
So there is a 106 firmware upgrade out now? Anyone have a change list for that version? Is the link in the same FTP folder as the 104 software?
post #272 of 430
I do have the sharpness turned up on 2d not sure if that's carried through on to the 3d mode, will have to check. Thanks for that.
Steve
post #273 of 430
Just an FYI for those owning a 3010 projector - while searching the Epson FTP directory for a possible 106 firmware for the 5010/6010, I found what appears to be firware upgrade 113 for the 3010 and 3010e - the name of the file is epson14650-PLHC3010_3010e_FW113.zip, and it's dated May 9, 2012. Not sure if that's an already-known firmware upgrade or not...
post #274 of 430
I just bought mine and it came with 105, how do I check mfg date?
post #275 of 430
whaaa? a new firmware out already?
post #276 of 430
I just bought one today and have the firmware 106.... Not sure what is different but have got 106 wink.gif
post #277 of 430
So it seems FW v106 is released.
Does anyone have a link to it and the release notes on what was changed/fixed?
post #278 of 430
I looked at the Epson FTP site where the 104 f/w is located and couldn't find anything about a "106", so I assume it's not been released to the public yet.  Or it could be in another location.
post #279 of 430
I now have a copy of the 106 firmware... It is not on the Epson FTP site as of yet. There is no release notes with it - it is only one .DLP firmware file, so you need to have the install files and instructions from the 104 firmware to install it. I just got it yesterday from another member who had contacted Epson Support directly and they emailed it to him. I have not installed it yet, all I know is it fixes a power on/off issue with the remote, which I have been experiencing with my 5010. It is for both the 5010/8000 and 6010/9000, just as 104 was.
Edited by FreyTheater - 8/19/12 at 5:45pm
post #280 of 430
i have no issues with power on/off so dont think i'll bother with installing it yet, but if it was to add other bonuses then thats a different story, but without knowing....oh well.
post #281 of 430
aahh, i have a terrible issue with powering ON with the remote on my 9000, 50% of the time it doesnt, FreyTheater, i would be much obliged for any link! (i have upgraded FW before with the virtual mode, so now how to do it) cheers
post #282 of 430
just for anyones info, have installed version 106 fine, on a uk epson 9000w - thanks to FreyTheater for his guidance and help
hopefully this will solve the erratic power ON issue via the remote.
post #283 of 430
Did any of the firmware upgrade solve the focus drifting that some reviewers reported????
post #284 of 430
I very much doubt it as both focus and horizontal/vertical movement are controlled through physical movement of dials rather than electrical adjustment
post #285 of 430
AGREED - it is HARD to get Firmware to TURN a MANUAL KNOB
post #286 of 430
Originally Posted by TgL View Post
I have now upgraded the european TW9000 (swedish) with the US 104 firmware and it works like a dream,i had to do virtual XP on a windows 7 home premium laptop.
I just tried to download MS Virtual PC, and it indicates I am not eligable...it needs MS Win 7 Professional.
You indicate you have Premium. How did you get Virtual PC?
It's unfortunate that Epson doesn't have method to do over internet (of course that would require it to have network capability...more hardware), and crazy that they don't support Windows 7.
If anyone has succeeded in doing the firmware update from Windows 7 w/o virtual pc, can you provide info on how you did that, and specifically what cables you used?
Thanks....
post #287 of 430
Point taken - been too much obsessed with autofocus on my dSLRs :-)
- is there any reason why drifting should occur if the projector is not moved or being shaken by powerful subs? :-D - or does it only affect earlier production runs?
I seem to remember that the Sony HW30 had similar problem
post #288 of 430
Have you tried focusing AFTER the projector has been on for 30 minutes?
It seems if you focus on a cold start up, the focus tends to drift until it hits around 30 minutes.
This does mean that for the first 30 minutes, the focus may not look as sharp once the adjustment has been made in this manner.
post #289 of 430
I do not Believe Webmonkey owns a 5010/6010
If he OWNED ONE HE WOULD NOT BE COMPLAINING
post #290 of 430
Correct, I do not - yet.
I used to adjust my Barco after 1 hour warm up....
I wanted to make sure that the model does not have a production flaw before I invest hard earned money....
post #291 of 430
I borrowed a friends laptop that had XP, that's prob the easiest route. Did you find these articles?
http://www.howtogeek.com/howto/11060/create-an-xp-mode-for-windows7-home-versions-and-vista/ This VMware player requires you have a copy of XP.
http://www.tomshardware.com/news/windows-xp-mode-windows-7-win7,10213.html
post #292 of 430
I'll look at those articles. Thanks.
This is pretty frustrating that they are operating in what feels like 1985 { ok...a bit of an exaggeration ).
post #293 of 430
The second of your links talks about how to install virtualPC even if not on Professional. Thanks. That should do the job.
post #294 of 430
Epson Support may be great for some, but was not so friendly with me. They wanted to know where and how I got 104, and would not send me 106.
post #295 of 430
Say...those of you using Virtual PC. When I put the projector into download mode, the Virtual XP pc does nothing to install the drivers. I did run the EMPSUB2SETUP.EXE within teh Virtual PC, not on my Windows 7 system. (By the way, I t ook the PJ down from ceiling and took it to my office to use my Win 7 Professional PC).
Do I need to install the program on Windows 7? I presumed I needed to do all functions within the XP Virtual PC.
[EDIT]
I decided it'd be a while before I get an answer here, so I tried running the driver program in Windows7. Did not help, so I have no idea what to do now.
Any suggestions appreciated.
Edited by Ewingr - 8/24/12 at 10:37am
post #296 of 430
[EDIT]
1. Did you install IDOLV305_Installer.exe & EMPUSB2Setup.exe
2. Are you certain the projector is going in to download mode:
"Power Button & Operation Indicator” LED’s are lit blue and the “Temp” LED is lit orange"
post #297 of 430
Yes I installed both of those in the XP mode. I installed the EMPUSB2SETUP.exe also in Win7.
Based on what I read in the instructions for determining it is in download mode, yes, I am sure.
I actually have not gotten to the attempt to download. I can't get the Epson to show up in a Com Port.
post #298 of 430
I got to thinking maybe I need to use a different USB port. I'm using one on front of my PC, because my Micro USB cable is very short. I picked through my stash of cables and found a USB Male/Female extending cable, and plugged into a USB port on the back. No go. In fact it was worse. On the front it at least knows it is an Epson device. Using the extension cable, it is seen as Unknown USB device. frown.gif
By the way, I'm seeing zero activity through all this in the XP Virtual Machine. Doing all this on the Windows 7 OS of the PC itself. I don't know if the XP should do the install or not.
Edited by Ewingr - 8/24/12 at 7:06pm
post #299 of 430
So now your trying it with a computer that has Windows 7 Pro? Maybe you want to just get the free XP version and run the update with that? http://windows.microsoft.com/is-IS/windows7/products/features/windows-xp-mode
The links I had referred you to are for someone to try if Pro isn't available.
I think the process has to be ran while in the XP mode virtual machine, as mentioned by another poster?
post #300 of 430
Well, from what I read, it is done the same whetherh on Pro, or not, with Virtual PC> The issue with it not being Pro is getting Virtual PC to even work. The articles you pointed me to offer how to do that. I thought I'd just drop that variable out.
But, now, to my surprise, I find that my wife's laptop is Pro. I guess I upgraded it some time or other. So, I'm installing Virtual PC on it now.
[EDIT]
Just looked at your link. That is in fact what is run inside of the Virtual PC, that is, XP Mode.
