AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official LG XXLM7600 Owners Thread...
Official LG XXLM7600 Owners Thread... - Page 50
post #1471 of 3596
here you go.
energy saving : off
picture mode : expert 1
backlight : 32
contrast : 75
brightness: 53
h sharpness: 0
v sharpness: 0
color : 50
tint : 0
expert control.
dynamic contrast : off
super resulotion : off
color gamut : bt709
egde enhancer : off
color filter : off
gamma : 2.2 or 2.4
white balance.
color temp : warm
method : 2 point and 20 point
pattern : outer
high : r -10, g 0, b +7
low : r +1, g 0, b +8
20 point
10: R +2, G +1, B -3
15: R +1, G +1, B -1
95: R 0, G 0, B +2
All Others: R 0, G 0, B 0
Luminance 130
cms settings.
Color Saturation Tint Luminance
Red -1 (0) -20 (-12) +6 (+5)
Green +19 (0) 0 (0) +5 (+5)
Blue 0 (0) 0 (0) +6 (0)
Cyan 0 (0) 0 (+10) +3 (+4)
Magenta 0 (0) 0(0) +4(+1)
Yellow 0 (0) -4(0) +2(+3)
picture option.
Noise Reduction: Off
MPEG Noise Reduction: Off
Black Level Low
Real Cinema ----
Eye Care Off
LED Local Dimming High
TruMotion Off
post #1472 of 3596
Hey guys. I just picked up the 55" size of this set last Saturday and am enjoying it so far, however, I do have a question about the software update. In reading many different threads on this site, I noticed that some owners of this tv have downloaded update 04.12.10, however, the latest update that I can download is 04.02.85. Just wondering what I could be doing wrong and hoping for some advice.
Thanks in advance!
post #1473 of 3596
Originally Posted by tpollagi View Post
I'm not sure what you mean with 50 Hz. I do remember problems watching golf depending on the True-Motion settings. After a tee-off when the camera pans accross the sky following the ball, the 7600 would actually show 2 balls. The trailling ball would flash and flicker appear and disappear. It wasn't a shadow or fuzzy trail; it was a complete 2nd ball about 2 ball widths behind the first. It was unwatchable.
Is this common cause i am experiancing the same 2 ball problem ? Is there a way to fix this ?
post #1474 of 3596
Thanks in advance!
you need to hack ur tv so that you can access to the service menu and get the beta update.
post #1475 of 3596
Originally Posted by caloyzki View Post
here you go.
energy saving : off
backlight : 32
contrast : 75
brightness: 53
h sharpness: 0
v sharpness: 0
color : 50
tint : 0
expert control.
color gamut : bt709
egde enhancer : off
color filter : off
gamma : 2.2 or 2.4
white balance.
color temp : warm
pattern : outer
20 point
95: R 0, G 0, B +2
Luminance 130
cms settings.
picture option.
Black Level Low
Real Cinema ----
Eye Care Off
TruMotion Off
I am surprised those settings are good for you, but certainly happy if you do like them. That backlight even in a dark room is just too low, much lower than any pro calibration I have seen. And in no circumstance can High Dimming be good regardless of the settings. It creates banding and makes everything dull. Colors have no pop and to my eyes scenes just do not look normal. I'm not a professional calibrator so I can't say those setting are "wrong" but I could not watch TV with them. Also not having any sharpness goes against any calibration disc, Pro calibration,the built in wizard, or my own eyes. Almost makes some things look blurry. Perhaps he made some changes elsewhere to settings we can not in the settings to offset the ones shown. That would explain it, except the High Dimming. But again if the result is perfect for you that is all that matters!
post #1476 of 3596
Thanks in advance!
Apparently some areas of the country have access to 04.12.10 update and others do not. I fall in the do not category. I'm stuck on 04.02. 85 here in Minnesota. I'm sure we will eventually get it.
post #1477 of 3596
That's the first thing that jumped out at me--NO SHARPNESS! That would be unwatchable, IMO.
post #1478 of 3596
i will post the calibration docs, as soon as my set get calibrated this coming oct. 23.
post #1479 of 3596
How about some 3D settings.
post #1480 of 3596
Hi All just picked up this TV from Amazon it will be here on Friday. Just a couple of questions:
1) How is the input lag on this Tv? I am big games and play COD MW on my xbox 360 all the time.
2) How reflective is the screen? My living room is bright and i do a get ambient light.
BTW i bought the 55inch version
Please advise.
Thank you.
post #1481 of 3596
I am having an issue where some still screens like the start up screen and menu screens for my wd live have a little blur or a little fuzziness on the text and edges. And when watching Sons of anarchy through my cable box last night had instances with some blur at different times. this is with out of the box settings I am not sure which mode I am using, but I tried a few different ones. I haven't played a dvd or anything yet. I really noticed bad when there was some fine small print at the bottom of the screen it almost looked like it was in 3d mode or something. it was like there was two layers of the text. text is the worst that it does it on. Is there anything I should try in the settings before calling LG or returning the set.
post #1482 of 3596
There's your answer!
post #1483 of 3596
I have the disney wow disc I was going to use and I also have a free professional calabration I am going to call for from best buy since I am a silver rewards member. But is there any base line or anything I need to use. The fuzzy print and menus is really annoying and makes me wonder if it is defective
post #1484 of 3596
i prefer to use this app rather than the magic remote. also it can take snap shots
post #1485 of 3596
I agree. I see a lot of "professional" calibration settings on this site, and the backlight is always extremely low. How are you guys watching this TV in the daytime? It has to be virtually impossible. It might work in a completely dark room, but I just can't see the picture as being any good at around a 32 backlight.
post #1486 of 3596
It's either your TV or your video source. What are you using for a video source when you see the fast forwarding and skipping? Cable TV? Satellite dish? Blu-ray or DVD player?
I connect to cable tv box. tV is going back this weekend. There are no solutions. Some movies are fine, some are horrible, and the gaming on Xbox is completely lagged. Anyone have any comparable TVs ideas?
post #1487 of 3596
Thanks in advance!
Some people have switched to the alternate download servers and are downloading betas. There are instructions in this thread on how to do that. You need a special remote.
My question is if we can connect to these servers on our computers, and download the files to a USB stick to flash on our TVs.
post #1488 of 3596
those who were able to go into service menu..canyou guys please check a nd confirm if there is any option to change NTSC to PAL video format. I heard that it was possible in the last year model.
You would be able to see by changing Country Group from USA to something else...dont remember...please confirm if you can to have PAL option selected.
Thanks in advance....and another thing, i heard, we can record tv programs with this tv by hooking up ext. hard disc in UK models ONLY. is it true?
post #1489 of 3596
Finally, I got through to some awesome techines at LG. Tech Robert helped me narrow down the WiDi issue. Not only does the LG tv and the WiDi equipped laptop have to be on the same network connection (both wifi or hardwired), it also helps to open up three (3) ports on your router. Finally, I needed to play around with the available wifi channels and choose one that worked best. Changing the channel made all the difference in the world. Finally, I can connect everytime without difficulty.
post #1490 of 3596
how?
post #1491 of 3596
Well, I tried this and while I can see some flashlighting I'm unable to capture it using my Canon digital compact camera. My eyes can see it but it's apparently too dim for the camera's sensors to pickup. It's more visible when the PS3 is hooked up without a hand controller present, but again, I can't get it to show up on a photo.
Thanks for trying.
post #1492 of 3596
will this set ever make it to CostCo???
post #1493 of 3596
just called LG for regular remote and they are sending for free..
post #1494 of 3596
You can not make that change on these TV's. A tech would need to use a computer to make that and many other changes.
post #1495 of 3596
Software 04.12.99 now available. I have not found any changes.
post #1496 of 3596
Hi where did you see the 04.12.99 update? I checked on the LG site they are not showing this update its still the old one 04.12.85
post #1497 of 3596
Just installed 04.12.99. Home screen is much more responsive and backlight tracking seems better. Trumotion still glitchy with 1080p/60Hz content. 1080p/24Hz is flawless and awesome!
post #1498 of 3596
I do now see the home screen is indeed faster loading, less lag with moving the pointer, etc.... I also noticed over the last couple of update Youtube plays very well now.
post #1499 of 3596
here you go.
energy saving : off
backlight : 32
contrast : 75
brightness: 53
h sharpness: 0
v sharpness: 0
color : 50
tint : 0
expert control.
color gamut : bt709
egde enhancer : off
color filter : off
gamma : 2.2 or 2.4
white balance.
color temp : warm
pattern : outer
20 point
95: R 0, G 0, B +2
Luminance 130
cms settings.
picture option.
Black Level Low
Real Cinema ----
Eye Care Off
TruMotion Off
Have you compared your settings to the well known Calibrated settings on the web? I put these values into Expert 2 and in comparison it's extremely dull, lacking color, and brightness. If you haven't I highly recommend you do, and if you find the populated settings online to be better I would get a refund for your professionally calibrated settings.
This is awesome, I am going to do the same thing in a few minutes and see if they'll send me one as well as the motion remotes novelty has already worn off.
post #1500 of 3596
Please advise.
Thank you.
The input lag is very very minimal. I would say its 5ms or less, I've done an input lag test in comparison with my 5ms Acer Monitor and it was identical after 8 minutes of running...
The screen is very reflective, I knew this and wen't out and bought Thermal Black Curtains for my windows....highly recommend it. Picture quality on this set is phenomenal though, so there are many positives, with a few negatives.
