Hi there, can anyone help me with this?... (I have also posted it in the AVR forum)
I am having problems managing to get my Amp to play sound from the TV via ARC.
I am using a Denon AVR-591 Amp and an LG LM7600 TV.
TV (LG LM7600) settings details are as follows:
Amplifier (Denon AVR-591) settings are as follows:
The one thing I have not tried is buying an optical cable and using a different source. But I really don’t think I should have to find “workarounds” of something as ubiquitous as HDMI ARC in order to play TV sound through my amp, when I’ve paid thousands of dollars to do so. This stuff should be easier, seriously.
Anyhow - this has driven me to the edge of insanity. Please. Save me from my technology.
- Both units support ARC.
- The units are connected by an HDMI 1.4 ARC cable.
- The cable is plugged into the correct slots labelled as ARC... on TV: HDMI IN 1 (ARC); on AMP: Output Monitor (ARC)
- I have a Foxtel (Satellite) signal going into the Amp. When I select input: HDMI1 on the TV, and set the Amp to play Foxtel, the picture and sound both work. But when I play anything on the TV (eg- a movie via the TV’s USB input), I get no sound.
- TV Input set to USB. USB flash drive plugged in. If I select “TV speakers” on input screen, the sound works fine through the TV.
- If I then select Simplink = ON and Sound = “External speakers”, I do not get any sound through the Amp speakers.
- The TV gives me a message box saying “if you cannot hear sound, check the speaker volume or optical cable. If home theatre power is turned off, it may take a long time.”
- Simplink = ON
- ARC mode = ON
- Digital sound out = Auto (not sure what PCM means – the only other choice)
- Input = TV
- Input mode= -ARC
- Decode mode= Auto
- Input assign... TV shows as “-“. When I toggle down to TV, the “[ENT]:Select” option disappears. This might the biggest clue to my problem
- HDMI audio out= AMP
- HDMI control= ON
- Other info from 2-3 HDMI signal info: [Rep=1080; Colourspace=4:4:4; pixel depth=8bits; Interface=HDMI 3D
- When TV input is selected, the AMP displays "VIDEO ONLY TV"
![Wow: World of Wonder [Blu-ray]](http://cdn.avsforum.com/1/11/50x50px-ZC-1166fb14_B00462PTDQ-51E0ByQYHsL.jpeg)
