AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official LG XXLM7600 Owners Thread...
Official LG XXLM7600 Owners Thread... - Page 93
post #2761 of 3652
Originally Posted by klago View Post
It's motion jerkiness seen when watching live sports like golf or hockey. It looks like the picture stutters as the player is swinging his club or as the ball is rolling on the green.
That's not judder. It's confusing. The current term for that is display motion blur. Note: "Motion Blur" by itself is a broader term
most purists regard that as the blur that comes from camera shutters staying open during motion.
post #2762 of 3652
Originally Posted by tampa8
I can only answer what is asked. Since he was specific, that's the correct answer for that question. smile.gif
Fix your quote on that message.....you made it look like I said that, which is uber-confusing.
post #2763 of 3652
Originally Posted by Tim Duemig View Post
Well it looks like LG must be admitting that there is a problem with latest firmware because the Tech is here, he just changed out my mainboard, and it is forcing an update of the software, however it told him the latest version avail for download is 4.31.30, not the 4.31.31 that screwed up my TV originally. I'll update everyone once all testing is completed.
Ok, so an update on my situation... it's been roughly two weeks since LG tech replaced my mainboard on my 47LM7600 to fix the firmware issue they had (terms kept popping up when turning on tv, smart features stopped working, etc..). The TV seems to be working fine except I noticed something very strange last night. The TV model now shows as GLOBAL-PLAT4_B5, and has a different serial # than I had before. So today I tried the LG remote App on both my iphone and android devices. Neither will control the tv. It tries to scan the network for the tv, a box pops on the tv for pairing code, but the ios and android apps say "unsupported device". I don't even get a pairing code to enter.
I called LG and they told me it was user error. I told them BS.... this worked before. So, they are sending a tech out again. As much as I love this TV, I am growing more annoyed with LG and will be hesitant to ever buy another TV from them again. I have Samsung, Vizio, and Philips TV's elsewhere in the house and never had an issue with any of them.
post #2764 of 3652
How do you all feel about the reflectivity of the screen? Checked out a floor model in Fry's a couple days ago and it seemed a little reflective for my taste... Anyone seen it next to a Sony HX850?
Maybe I could get used to the glare...but it's gonna be in a fairly bright room with daylight during the day and lights at night. Thoughts?
post #2765 of 3652
Thanks for clarifying the terminology/nomenclature.
So how do I fix it?
post #2766 of 3652
I have 558600. When I watched TV program and listen the sound throuh receiver, the sound was off for about a second from time to time. Same as when I play PS3 that connect to tv, the sound from TV speakers was off from time to time. Can anyone help?
post #2767 of 3652
Originally Posted by Vinnie M View Post
Looks great! What mount are you using? Are you happy with it?
this is the mount i used for my TV. http://www.bestbuy.com/site/Sanus+-+Wall+Mount+for+Most+32-70%22+Flat-Panel+TVs+-+Black/9848075.p?id=1218183917144&skuId=9848075 and yes i am very satisfied very slick and nice looking.
post #2768 of 3652
Originally Posted by tampa8 View Post
As I posted earlier the Harmony remote automatically has the command after adding the LG TV to it. If you are getting a universal remote anyway, that would be one solution. Much cheaper of course is one of the recommended RCA remotes.
So I grabbed an RCA RCR312WR from Walmart and followed instructions to use 5 digit code 11265 to connect to the LM7600 & then press the guide button to access the EZ menu but unfortunately this didn't work. Apparently 11265 is no longer an valid code even though it apparently worked at one time according to a tutorial I found. I really wanted to do this on the cheap but I may need to purchase the cheapest harmony 300. I appreciate all of the help!
post #2769 of 3652
i access my service menu by using RCA remote from best buy. it cost me 10 bucks.
post #2770 of 3652
RCA RCR312WR, bought from Amazon, and it worked for me.
post #2771 of 3652
Do you mind posting your remotes model #? I can run by best buy later and try that one instead if they have it!
post #2772 of 3652
According to the model # printed on my remote I have the "exact same" remote but when I enter code 11265 while holding TV it the power button on the remote flashes 4 times like it wasn't a valid code. frown.gif Maybe this remote is a new revision that has that code removed? Would they do that? I may try the IR LED/HEADPHONE JACK rig to see if that works. I wanted to try and get this done today so I could record the SuperBowl so that limits my options as far as ordering anything online. Anyway, I appreciate all of your help/input thus far.smile.gif
post #2773 of 3652
So you can record the Superbowl? There is nothing getting to the service menus will do to get to recording anything unless you are outside the US and using a non US version of the TV.
post #2774 of 3652
Sorry I was under the impression that I could turn on the PVR(Time Machine) in the service menu even on North American versions of this TV. I guess I read that wrong!
post #2775 of 3652
That feature is not available for us. In fact getting you into the service menu's does not allow for many changes, however there are a couple. Most items are greyed out and can not be changed with a remote by anyone, it takes a computer connected to the TV with the correct program.
post #2776 of 3652
this could be where the confusion came from: "can" used instead of "cant"
2. You can use/turn on the Personal Video Recorder function, or any greyed out function even with access to the service menus.
post #2777 of 3652
Gotcha! Thanks for taking the time to answer my questions.
post #2778 of 3652
You are correct, should have typed Can't -
post #2779 of 3652
here is what is used to access my service . http://www.bestbuy.com/site/RCA+-+4-Device+Universal+Remote+-+Black/1088116.p?id=1218219329422&skuId=1088116&st=rca remote control&cp=1&lp=3
post #2780 of 3652
Wow the prices on this thing are stubbornly being held high. I think they're trying to hold out right before the slide that happens when the new models trickle in from feb to apr.
I hope something happens, because Light Gray Friday was such a @#$%ing disappointment across the board.
post #2781 of 3652
so is there any way of enabling the DVR functionality on the 47LM7600 for US versions? If so can someone please explain how to do so. Thanks!
post #2782 of 3652
Thnx, Pwrwrap, did that. (It's better.) The three-point base is also too narrow at the rear and always lets the remote falls over...think I need an old hacky-sack (or small beanbag) to put under it on the coffee table so its not always falling on its side (and rolling onto the floor usually). I got a Hulu+ subscription free for 3-months (as opposed to the free week from my new ROKU (in the bedroom) and this LG TV for Hulu)...but I am still wondering if it's possible to get Amazon Prime on the 2012 47LM7600? Anybody got a clear, concise process/method to get this? Isn't it supposed to be coming form LG on a S/W update?
post #2783 of 3652
Actually sometime over the last week I see I got another update to the Amazon App a slightly different look to it. It and Vudu are the apps I use the most by far.
post #2784 of 3652
Answered just a few posts ago.
post #2785 of 3652
See this post on how to enable Amazon: http://www.avsforum.com/t/1399636/official-lg-xxlm7600-owners-thread/2430#post_22797125
post #2786 of 3652
Hi, I just purchased this set a few days ago and so for it's been great. There is one thing that irks me and I am hoping it's just a setting that I can change but have yet to find. I would like the TV to default to the app screen if no HDMI device is powered up. Is there a way I can do this?
post #2787 of 3652
Harmony remote. The set itself can not, but it's one simple push of a button after power.... smile.gif
post #2788 of 3652
There's are *lot* of things that could so easily be managed if TV's followed a 3rd party addon model, like Firefox and the like.
post #2789 of 3652
It's pretty damned reflective. If that's going to bug you and you don't have a way to close window curtains/blinds, re-angle lights or have a spot you can place it in which doesn't get hit by either of those it might not be the best choice for you. I haven't seen the Sony you're referring to. My living room gets a lot of ambient light from 2 very tall windows and 2 doors with windows in them and I have relatively sheer curtains so watching anything dark on it during th day is kind of useless, but at night I use two specifically angled lamps rather than the overhead and that works fine or I can just turn the lamps off. For day time use, I can angle it toward the love seat rather than the sofa and it gets less reflection that way but the love seat is too small to stretch out on obviously. I don't regret buying it at all and would have gotten it even knowing this ahead of time but I don't watch much if anything during the day and if I do I'm usually multitasking so not paying much attention to the visuals anyway. This might not work for your needs, though.
post #2790 of 3652
I haven't seen it next to that Sony, but my friend has that Sony and from what I remember, they're both pretty reflective.
My solution to the reflection problem was to mount the TV on a tilt mount and angle it slightly downward. I have a wall of windows to the side of the TV, and spotlights on the wall behind where I sit, and tilting the TV downward minimizes the reflection I see of both of them.
