AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official LG XXLM7600 Owners Thread...
Official LG XXLM7600 Owners Thread... - Page 108
post #3211 of 3594
Originally Posted by MMcCraryNJ View Post
I have to pick me up one of those WOW disks. I actually found that using the Vivid setting for my cable tv input and scaling the brightness/backlight down fair a bit actually looks really good. Besides, it's just TV so accurate colors and all of that don't mean much to me. I would like to get some accurate settings for Blu Ray movies and my PS3/360 though. I've tried the CNET settings and the picture just looks incredibly dull and lifeless to me, lacking sharpness and things like that.
I would use CNET's basic settings as starting point and look around this forum and a few sites and mix and match to find your perfect settings (see below). I would recommend WOW to anyone that wants to have a comprehensive explanation of how-to and why calibration helps get the most out of your display. In most cases a calibrated set will have a "dull" look because colors are adjusted to be accurate not over saturated.
You have to like the way your set looks, so adjust until it looks right to you. Here are a few links:
http://reviews.lcdtvbuyingguide.com/lg-lcd-tv/lg-lm7600-calibration-settings.html
http://forums.cnet.com/7723-19410_102-573198/lg-47lm7600-picture-settings/?tag=contentBody;threadListing
http://www.flatpanelshd.com/review.php?subaction=showfull&id=1333359799
http://www.avsforum.com/t/1406222/lg-55-55lm7600-calibration
post #3212 of 3594
Originally Posted by caloyzki View Post
i guess, i am on engineering update. maybe in a couple of weeks for official update.
Cool thanks.
post #3213 of 3594
Picture is always based on taste in the end. That said, those CNET settings are spot on for a very natural look. Faces should look as natural as possible. Did you make all the settings CNET has? I can tell you, WOW is not going to be much different than the CNET settings, and worse if you zero out the settings you made. WOW can make the saturation and color balance correct, but many subtle changes that a pro would make are included in the CNET settings. If WOW did have very different settings one would have to be incorrect.
You would be better to not get WOW if CNET is not to your liking, and simply use the CNET settings and then change the saturation or hue to your taste. WOW is simply going to confirm the CNET settings are just about right with any real change being in brightness or contrast. Even then it won't be that great of difference. Why buy WOW then disregard what it says is correct, just do that now with the CNET settings.
WOW works for many of us in conjunction with CNET because all we want to do is tweak it a little based on our room the TV is in, not drastically change it.
Edited by tampa8 - 3/16/13 at 11:33am
post #3214 of 3594
So I think I just discovered something interesting.
I use this TV mostly for PC games and movies and with Xbox and ps3. I had all of my inputs labeled as PC because I wanted 0 lag for gaming. But then I thought I read somewhere in this thread that the newest update 4.31.43 made it so the gaming input had 0 lag as well. I also always disliked the fact that the PC input would not allow you to get into the color management menu or to use true motion settings.
So today I tried changing my computer from the PC input type to the gaming input type. I was able to go into the color management settings and set them up with the CNET settings and I was able to use the tru motion settings as well, but I noticed there was lag which I didn't like. This forced me to go back to the PC input label.
The thing is that I'm pretty sure all of the color management settings that I adjusted stayed adjusted even when I went back to the PC input. It might just be in my head but it looks a lot better than it did before.
post #3215 of 3594
If I am not mistaken you can do white balance and color management are available in (input) PC and Gaming. I believe it now allows for local dimming adjustment.
post #3216 of 3594
For me color management is not available in PC input.
post #3217 of 3594
You are correct the CMS is not available with PC input, but was able to in "game" input label (PS3).
post #3218 of 3594
How to get my LG LM47 7600 TV to recognise my iphone 4S in the LG?
Wi-Fi Screen Share feature in the NETWORK menu screen is turned to ON
in the SMART SHARE SETTING SHARE MY TV is ON
TV is on a wired ethernet connection and iphone is on the same network but via wifi.
When Screen Share searches for devices it can not find my iphone? any ideas
What I have got working is
LG TV remote App
imediashare (but this is quite different to Screen Share right?)
both on the iphone 4s.
regards
post #3219 of 3594
I gotta decide in the next 24hours. Should I go for LM8600 or LM9600. That cnet review on 9600 is so horrible - so me thinking 8600
post #3220 of 3594
Save yourself some money and go with the 8600. In my humble opinion.
post #3221 of 3594
LG TV remote App
regards
I have the very same issue and setup. Help!!!!
post #3222 of 3594
WOW was $17 last I looked. I think he should try it regardless.
BTW, does LG have a way of storing several settings away in a human-readable file? XML or something, or is that asking for something a little too sensible? And then allowing a person to quickly choose between them?
post #3223 of 3594
Yes. The 9600 seems outstanding, but only on paper.....Note: I never did see this set in person, but I have seen an awful lot of disappointment and outright anger among folks regarding it and it's ridiculous pricing. Even if it's $2k right now, spend $1.5K and get the 8600.
post #3224 of 3594
Cool thanks.
which are your settings for 3d,2d tv and games?
post #3225 of 3594
what are steps 2 get rid of the adds in the Smart TV section?yes I know it's been posted before. Thanks
post #3226 of 3594
Block the site in your router.
post #3227 of 3594
We're someday going to see a lawsuit regarding this I think. A TV manufacturer is overstepping their bounds with this idea.
post #3228 of 3594
Hi
klopez3709
LG replied to me with this
The TV will not recognise the software interface of your phone. You may need to download a third party application to set up media share on the phone.
I have emailed them back asking them why one of if not the most common phone doesnt work with their TV, which phones do work (LG only?) and that I already have the imedia share app but its using DLNA I think, is slow, takes ages to convert Camera Roll videos or pics and is not the same as Screen Share.
Thats my knowledge anyway thus far
See what they say
Anyone else out there?
post #3229 of 3594
I don't have any idea if its the same thing - but I do have mirroring with my IPad and Apple TV - I think I'll. just stick with that.
post #3230 of 3594
I am wondering if its not LGs fault but the iphone, as in Apple and its 'special'software not allowing it without of course going and buying the Apple TV?
Maybe I should try a friends Samsung.
post #3231 of 3594
Question
What brand and size HDD to people recommend to use with the LM7600 in its capacity as a DVR to record TV and timeshift?
I was thinking the Black Caviar 1TB
or
Seagate Barracuda 2TB ST2000DM001
though the USer manual says you can go to 2TB, LG support said only 1 TB..
some ideas here
http://www.bestcovery.com/best-hard-drive
http://www.harddrivebenchmark.net/hdd_value.html
Also what about a SSD? the userguide recomends against it but if it survived for 2 years and meant significantly faster timeshift times I would be happy.
One thing I do find annoying and as yet untested on my LG TV is the variance in devices competency to quickly timeshift, an old LG analogue Tuner/HDD was very quick but other I have take noticeably longer (all measured in seconds of course)
Regards
Edited by John Delroy - 3/18/13 at 8:20pm
post #3232 of 3594
Unless you have found some way to do this, or are not in the U.S., or the latest software now allows, that option is not available on this set in the U.S.
post #3233 of 3594
Well I spoke to a helpful LG tech today and he said the problem with LG TVs and iphones not being recognised as a device is IOS
so its Apples fault. They obviously want me to buy another device (Apple TV) to make it work.
More reason for me to change me phone to say a Samsung which though my tv is LG it will communicate fine via ultra fast Direct Wif Fi Screen share.
I told him how slow imedia share app is, how it needs to convert Camera Roll photos and videos and he confirmed DIRECT SCREEN SHARE plays straight away, so its a definite loss not to have it.
post #3234 of 3594
New Firmware this morning: Doesn;t appear to have changed anything though. Still no Amazon VOD and no release notes to check.
post #3235 of 3594
For some reason, LG does not list it on the site yet - that I can find.
post #3236 of 3594
Yeah - noticed that to. Was hoping they would have some sort of release note...but the update was available when I turned it on this morning. Forgot to write down the version number...but im pretty sure it was 04.34.xx, just can;t remember the last 2 digits.
post #3237 of 3594
Honestly, I don't think it's ever happening. I can only speculate what the hold-up is, but Tampa8 claims his clandestine AIV is smooth, so perhaps it's not the CPU drain issue, but some DRM licensing crap that LG just doesn't want to deal with.
Again though, don't worry about it. The streamers are so incredibly small, and they can tuck behind a TV, and it's /all/ the streamer companies do, and and and and.....
post #3238 of 3594
I have had my replacement LM7600 for a week now and am loving it. I have all the missing menu features of my las and no "Real Cinema" issues with flickering film playback. I have near "0" light bleed and with local dimming at low-medium stellar( for edge lit IPS panel) black levels. I will post my settings for the set and after the required 200hrs of use by Geek squad will have pro-calibration. I will post those settings for a night mode since my viewing area is theater dark (with bias light) and 3D.
post #3239 of 3594
@ Tampa8
I was reffered to you by the cool tgm1024 with my sync issues on my LM860v combination with LG bluray player, sync issues when watching 3d blurays, hope you could help me.
LM860v ->ARC HMDI ->bluray 3d player. Only when watching 3d blurays, there are sync issues for about -300ms, all other media syncs correct. Now I have enabled AV sync with bypass on the 860v, but to no result. Any idea where this comes from? Both sets are firmware upto date. But when the sound is comming from the TV, also no sync issues.
post #3240 of 3594
Originally Posted by mohawk0618 View Post
@ Tampa8
Thanks for the complement, but wait a minute, now I'm confused. 3D could well by itself cause more lag since it's doing more processing----but your cable configuration I no longer understand. I thought you were saying something else.
Let's go over this from the beginning:
If you are doing this:
BR ----(HDMI)---> LM860V
How is the (lagged) sound getting to the receiver? The ARC can't land on a blu-ray and go anywhere.
If you're are doing this:
BR ---(HDMI)---> Receiver[config'd for ARC] ---(HDMI/ARC)---> TV
Then the TV is supposedly back channeling the sound to the receiver. The BR should not be performing any lag duties (ms delay) at all.
The sound would travel this route:
BR ---> Receiver [straight through the receiver and not its speakers] ---> TV ---> Receiver [and to the speakers]
By the way, your receiver needs to be using the ARC configured HDMI ports so it knows to pass it through on the first pass.
Edited by tgm1024 - 3/19/13 at 12:30pm
