AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official LG XXLM7600 Owners Thread...
Official LG XXLM7600 Owners Thread... - Page 116
post #3451 of 3922
Originally Posted by JackN View Post
Anyone have any thoughts on the calibration for the lm7600/lm760T posted at flatpanelshd.com? Of those I've tried on my set, feels more accurate to me...and I haven't seen it mentioned anywhere. Curious to see how it stands up to a more scientific look.
For those interested:
http://www.flatpanelshd.com/review.php?subaction=showfull&id=1333359799
By the way, do the best calibrations make use of both White Balance and Color Management System settings? Seems to be an either/or proposition; I haven't seen a calibration listed that used both.
--Jack
Cnet, and their settings are more refined. Flatpanel was mentioned earlier in the thread.
post #3452 of 3922
Originally Posted by eric3316 View Post
I would just question the sharpness at 50. Most people prefer it at 0 but a little bit can't be okay as well. Go to high and thinks start to look weird, especially faces.
Yes, too high, it's almost like they used settings from previous LG TV's that went 0 to 100, which would translate to 25 in this TV.
post #3453 of 3922
Originally Posted by eculley View Post
I'm confused.. on the IRE settings, do we have to edit each individual IRE?? I found some settings that made changes to each IRE.. so I have to go to each one and make the changes?
Seems tedious.
If it was a push of a button there would be no need for professional calibrators!
post #3454 of 3922
Has anyone had luck getting a TV with 0 flashlight bleed through? Mine is nearly perfect but has a 3-5 inch flashlight on the bottom right. Is it work attempting a replacement?
post #3455 of 3922
how is the uniformity in this tv ?? i heard on full white image,the edges are darker compared to the rest of the screen ??
post #3456 of 3922
Yes, I tend to 'season to taste' on backlight, contrast, brightness, sharpness--depending on the source--and they went for overkill on the latter. I'm focused on getting the color balance right, and--so far--the results from flatpanelshd are very natural looking. Simpler than CNET's--flatpanelshd only utilized the white balance adjustment--but I do like the results better.
Edited by JackN - 4/23/13 at 9:58pm
post #3457 of 3922
Ah, thanks. I still have CNET's calibration in one of my ISF modes, so I'll do some more direct comparison. My initial judgment was that CNET skewed a little too warm/pink.
Edited by JackN - 4/23/13 at 5:46pm
post #3458 of 3922
I have an odd question. I mounted this tv awhile back. I am moving to a place where i cannot mount so i need to re-attach the stand. I lost the screws hat connect tv to stand. Anyone know what size scews i need? I have never had something that i needed screws for and didnt have at least one to compare to. Help!
post #3459 of 3922
You're in luck--I have mine in a little bag.
The threaded part is about 3/4" long. There are about 19 turns of the threads per 1/2". The outside diameter of the threads is just a hair over 1/8". The head is 1/4" in diameter and there's a lock washer on each. You'll need eight screws.
post #3460 of 3922
I talked with some tech which I doubt he was incorrect and says you really can't calibrate a led screen it is mostly for projection tvs:eek:
post #3461 of 3922
I am still loving my isf pro calibrated set. Very worth it what i paid to kevin miller, one of the best calibrator in the planet.
post #3462 of 3922
who's kevin miller ?
post #3463 of 3922
Google is your friend.
post #3464 of 3922
Oh Jayzis........
post #3465 of 3922
If anyone is tormented about spending too much money on this thing, there's a used 55" 7600 for $1044.08 (Amazon warehouse / prime) and another for $1022 that purportedly only have a minor imperfection on their stands. (And missing screws and manual). Whatever. 30 day return policy.
You can only get a 1 year square trade though......so you have to be the "used is ok" type.
I'm not.
post #3466 of 3922
I just had my panel for my 55 7600 replaced by geek squad. The techs name was John who worked for Samsung for a number of years and did a great job. The bleeding looks to be non existent. Will follow up in a few weeks to give the panel sometime. It was quit the experience to see the work done. Yes, I was nervous as hell. I have photos of the service too. Will try to post.smile.gif
post #3467 of 3922
Turn auto-dimming off, boost the backlight, and show a black screen in a dark room, with and without a small bright object drawn on it (in case the TV knows to turn off all lights on full-on black screens). It's a tough test for any TV, but if you have it, it'll be there.
Ideally when I get off my ass and make it, I'll have a bleed tester that draws a bright bar through the middle of the screen stretching left to right with the rest black, followed by a bright bar going vertically. Each bar will move. Then I'll move a small bright box around.
Far easier than all of that though is the critical "real life" test that bothers folks: watching of a letter-boxed movie. Typically they are 21:9 and squashed vertically to fit the 16:9 screen. This give you the black bars on the top with the top and bottom lights required to be on.
Edited by tgm1024 - 4/26/13 at 6:07am
post #3468 of 3922
I have trouble visualizing where bleed issues originate, so I'm looking forward to the pics. Is it always the panel itself that goes bad...or can these issues sometimes be remedied by re-seating the panel in the case, sealing any source of LED light bleed, etc.?
post #3469 of 3922
post #3470 of 3922
I will post the pictures in gallery under my name.I am watching a letter box movie at the moment and it looks perfect.
post #3471 of 3922
anyone try or likes the calibrated settings from http://www.flatpanelshd.com/review.php?subaction=showfull&id=1333359799 ?
Picture preset: Expert1
Backlight 47
Contrast 85
Brightness: 50
V/H Sharpness: 50
Tint 0
Dynamic Contrast Off
Super Resolution Off
Colour Gamut Standard
Edge enhancer Off
Color Filter Off
Noise reduction Off
Mpeg noise reduction Off
Black level Low
LED local dimming Off
TruMotion Off
Color temperature Warm
Gamma 2.2
RGB Method 2 point
R high -6
G high -11
B high 18
R low -1
G low -2
B low 4
I'm guessing real cinema off and color 50?
post #3472 of 3922
Has anyone paired this set with either of the new blu ray players namely the lgbp 730 or lg bp530?
post #3473 of 3922
They are actually M4 screws if you need to be more exact here is a installation guide from the digital operators manual for reference (If you haven't already bought some screws.)
post #3474 of 3922
post #3475 of 3922
Got mine paired up with one of the older ones....BP325W (The 3D one they made especially for Black Friday with all of 4 apps)
post #3476 of 3922
if you are adding/looking for 3d glasses maybe you guys can grab one of these for $2 http://www.bestbuy.com/site/LG+-+Cinema+3D+Glasses/6500421.p?id=1218747897781&skuId=6500421&strId=478&strClr=true
post #3477 of 3922
I think he means "Here is a link to my Flat Panel gallery."
:-P
post #3478 of 3922
:-P
thanks!
post #3479 of 3922
Interesting. Doesn't look like they engage with the "inner workings" at all... Sort of a cartridge system, then? Slide out the old, pop in the new? It'd be interesting to see a panel module cracked open to get a look at just what causes back-light issues, how they might engineer a solution for these widespread problems. Thanks for the pics!
post #3480 of 3922
1.99 can't go wrong
if you wear prescription lenses the best clip-ons I tried and liked - Hurry get them there going fast http://www.amazon.com/gp/product/B007BPE4O0/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
