Short story is: MY 7 year old Sony LCD WEGA 60 Died this weekend
I hear I can try the bulb or get a repairman, and I almost tried. Unless someone really thinks it might work I will just get an upgrade. I am really interested in the Samsung 60 smart LED, however I see that the 55 inch is way less and might compromise to save that 500-1000 US dollars.
I was told that my 8 year old denon will need to be replaced to accommodate the 1.4 HDMI interface if I want to run it all correctly. Is this true? I found a 500 Onkyo that looks okay to do the job. I have: Comcast Cable box, Old DVD player (will upgrade to bluray upon advise) 8 Year old denon and NO Video Games as of yet.
Do I have to upgrade my Denon to make it all work right? How will it all hook up together if I want it to be set correctly? I also have great speakers which are no problem.
Any other advice to sway me to the 60 inch or to a better/cheaper Receiver?
Where are the cheapest best places to buy, amazon? I don't mindusing the Internet to buy.
I know this is alot of Q's I just want to make it all work for under 3k.
Thanks in advance!!
Thanks in advance!!
