AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › Wiring Projector for 3d + splitter Q - 1.4 HDMI required?
post #1 of 3
So I am wiring my theatre room and would prefer not to do this again... major headache! I plan on purchasing a 3d projector and will use my ps3, computer, (and next gen of consoles?) for 3d gaming and videos.
I already have a 1.3 hdmi cable, do I need to buy a 1.4 hdmi cable to run from projector to wall. then into the wall will be a splitter, again, do I need a specific 1.4 splitter for my 3d devices?:
Projector----HDMI----Wall Plate----SPLITTER---(computer, ps3, xbox720, cable box, etc.)
post #2 of 3
As long as the cable is High Speed HDMI cable, you'll be fine.
As of the HDMI 1.4 specification, these are the following cable types defined for HDMI in general:
Standard HDMI Cable - up to 1080i and 720p (I could play 1080P fine with short Standard HDMI Cable)
Standard HDMI Cable with Ethernet
High Speed HDMI Cable - 1080p, 4K, 3D and deep color
High Speed HDMI Cable with Ethernet
post #3 of 3
Sorry, no. *NO* 1-meter HDMI cable is worth a hundred bucks... That's ~20x the lowest price ones, which will work just as well. Anything above $10-15 is a ripoff. You get to 15'+, then we can talk about something more expensive, but still <$100.
  Back to Forum: Home A/V Distribution
