AVS › AVS Forum › Industry Area › HDMI Q&A - The One Connector World › HDMI BenQ W700 / Denon AVR1612
post #1 of 2
Ok, so I pulled the trigger and ordered my BenQ W700 projector and Denon AVR-1612 receiver which should both be here this week. I will have about a 30' run for my HDMI cable. Any recommendations on what will work best?
post #2 of 2
You're probably OK as long as you get a good higher-gauge HDMI cable from a reputable source. What you would like to be using is a High Speed HDMI cable, but the max on those is approximately 25'. So, you may be outta luck.
However, a good Standard Speed HDMI cable (see Monoprice or Blue Jeans Cable) should work for what you'll want to do (1080p/60 and 24). Can't guarantee it, but your odds are really good at 30 feet.
