I'm planning my theater, and one area that I don't know enough about is sub design (and the more I learn, the more I realize I don't know). I would like to have a sub that plays down in the 10-15 Hz range, but I'm not sure how to do that without spending a fortune on amps. I know the DTS-10 would get there, and I was strongly considering buying two while they were available as kits, but the timing just wasn't right. I'm considering an IB, but there are obvious logistical considerations that have to be worked out there. I think there are some sealed subs that will get there, but from what I understand it takes monumental amounts of power for them to do it, which is also pronounced expensive.
Are there any DIY, or partially DIY alternatives that I haven't considered that will play that low without breaking the bank on amplifiers?
BTW, if there is a thread that discusses this a link would be awesome. I tried searching, but there's just so many ways of saying "<20 Hz" that I didn't really have any luck.
Honestly with a budget like that you have a WHOLE lot of options, and if you are willing to give up the space that two DTS-10's would take up, that opens the door even more. So far the DTS-10's are third on my list for lower extension, my LLTs second, and my current sealed setup 1st for the fact that it handles the whole bandwidth better...
