Kick you in the chest is the 50-80hz range.
Make you feel like your drunk and underwater is 15-25hz.
You should have both covered with either solution.
Just watch the nulls, in a room that size you will get lots of them, and not just
left right front and back, but height nulls too. You can sometimes find spots to sit
where just moving your head an inch one way or the other will put one ear in and
out of a null. The louder the output, the more pronounced the effect.
Multiple cabs and placement are the easiest way to deal with nulls. Of course it can also
create an inconsistent listening distance setting so there are a lot of variables you
should watch out for.
