Whats your opinion of this dual sub placement?
I just got another 15" sub and have placed them in the front soundstage instead of one in the front and one in the rear, what are your opionins on this. I have heard with 2 subs place at the same distance on the front wall and the other on the rear wall would be best....my questions are:
1. I have a laminate floor behind MLP, I know this will effect the bass but how bad?
2. I can not put a sub directly in the middle on the front wall, I can on the rear. I am using isolation pads just incase anyone asks.
3. Is the sound quality going to be that noticable.....I have to run a 30-40ft cable to do this and hope it is worth it LOL!!
Room Measurements: 25 ft wide and 27 ft deep and ceilings are 6.9"
Accoustics:(Figured I would list this in case it helps on a decision)
Bass traps: GIK Tri-traps fromm floor to ceiling in all 4 corners
Rear wall: 3 X 7.5" "monster bass trap and QRD diffussers
All other reflection points Ceiling, side walls done with 242 accoustic panels.
Pics of Room:
Current location:
I am standing where the other sub is basically so you can see the space I have behind MLP:
Pics of Room:
Current location:
