Originally Posted by
nooshinjohn
Are you saying that you would trust an entry-level to mid grade receiver with a 4 ohm load to the surrounds? Wow....
Why not? All it takes is a deeper understanding of what's going on than you've thus far exhibited.
First, with the exception of a few full-range planers, there's no such thing as a "4Ω load" in real speakers. Rather, there will be a few dips, and a few peaks. So driving the a nominally 4Ω loudspeaker is really quite far removed from driving a 4Ω resistive load.
Second, surrounds aren't generally stressed very much. They're often closer to the listening position than mains. And they don't play sustained loud passages as often. So even lower impedances is unlikely to stress most gear, because it won't reach the gear's current-output limits.
nooshinjohn
The car hobby is much like the audio one, in that there is a flavor out there for everyone, and everybody has a differnt path to follow to achieve their personal definition of perfection.
That depends entirely on how one defines "flavor." If, as in your car examples, you're using actual differences such as looks, brand, heritage, etc., then you're absolutely right.
However, if you're defining "flavor" in sonic terms, then that is something that must be proven. And when serious attempts have been made to prove it, they've all come up with the "flavor" equivalent of distilled water. Unless, of course, one of the pieces of gear was broken or incompetently designed in the first place.
halo71
I am not going down DBT lane with you or anyone else. "I" can tell a difference between my old Technics receiver and one of my newer Onkyo receivers. I can tell a difference between my old H&K power amp and my Onkyo Integra M504.
You're not telling anyone anything interesting. I can hear a difference between my desktop system now....and now.
The difference? I changed the volume control a tiny bit.
What you're describing is more likely than not just mismatched levels along with a dollop of expectation bias.
halo71
So why are there capacitors of the same value with different costs?
Durability, for one thing. A cheaper electrolytic won't last as long as a more expensive poly.
But the boutique branded caps exist mostly because a critical mass of audio consumers are more deaf than smart.
