AVS › AVS Forum › Video Components › Home Theater Computers › HTPC - Mac Chat › problems with eyetv 3
post #1 of 2
I have had consistent problems since upgrading to eyetv 3. whereas I had very few using 2.x . I upgraded so I could use the net tv product but I still have an eyetv diversity.
there are two problems I experience. when editing the eyetv files the edits get screwed up. sections edited jump around at random. also sometimes audio gets out of sync with the video. and sections of the video develop weird frame rates., almost as if your processor can't run the video through lack of grunt but no problems there I'm running a recent model macbookpro. (running lion but same issue under snow leopard).
when exporting I get similar issues even if the eyetv file I'm exporting from does not have any issues.
i record a lot of tv so this is driving me nuts. I can't reliably count on eyetv to record quality or export properly anymore.
is anyone else experiencing similar issues. I can't believe I'm the only one but I've googled it and found nothing.
post #2 of 2
I use EyeTV 3 with an EyeTV Diversity tuner (in dual tuner mode) as well as a FireDTV S2 on the same machine and I can edit , export and watch without any issue. You might want to do a clean install of EyeTV. Use Elgato's EyeTV Reporter to remove all files belonging to EyeTV and reinstall clean. Make sure you have your serial number before wiping out the EyeTV install.
Rodolphe
  Back to Forum: HTPC - Mac Chat
