Originally Posted by assassin
My take? Completely depends on what you use your HTPC for.
If you are a videophile and have a 120" display in a separate theater using only uncompressed HD sources then Madvr can perhaps give you a benefit. Or a lot of people like Madvr because it helps with interlaced and SD material. Of course you have to substitute ease of use with the pains of constantly tinkering with all the settings of Madvr and MPCHC.
Or are you an average HTPC user that uses his HTPC to either replace cable/satellite or as a daily use HTPC with your HDTV for you and your family? Well here ease of use reigns supreme and the added 5% video improvement that you can squeeze out with all these advanced settings probably isn't even noticed. For this scenario then WMC and XBMC (edit: and JRiver) are VERY good and both look excellent.
What do I use? I use a combination of WMC+MB and XBMC depending on what I am testing.
What does my family use? Mainly XBMC right now (although my wife says she thinks she likes WMC+MB better)
What have I tested? WMC, WMC+MB, XBMC, MPC-HC, MPC-HC+Madvr, JRiver, Plex and probably some others.
This is a huge YMMV kind of topic and there is no real correct answer.
I use my HTPC in a dedicated theater room with 90" screen for mostly blu-ray rips. Ocassional OVA and sporting events.
I do like the WMC/MB setup, which I was using mostly for it's ease of use as well as a nice picture.
Btw, what vid card do you use in your HTPCs? There are a host of post processing settings on the video card control panel, do you shut them all off?
