I'm upgrading from my old Da-lite screen (matte white 1.0 gain) which works great with my Hc4000. I was thinking of getting some more of the same Da-lite screen material ($244.00) for my bigger screen, but i came across "Carl's place" screen material which is much cheaper. Under $100.00 for the same dimensions. Can anyone say if it peforms as good as the Da-lite i described above. I wouldn't mind saving some $, but not if it means sacrficing the screen performance i've been used too. Thanks.
