The Panasonic HC-X900M HD Camcorder is about to his the streets so here is an official owners thread to keep all conversations in one place.
Looking forward to testing out:
- low light performance given the faster (& wider) lens.
- the new Power OIS
- macro recording where subject is 2-3cm away from lens
Apparently, all of these are supposed to be better than the TM700 and TM900. You Tube videos in low light does seem there is a dramatic improvement. What do you do with your X900M?
- the new Power OIS
Apart from a wider angle lens, there is nothing that would push me towards the X900, and the wider angle lens alone isn't enough for me to upgrade from the TM900. It's clear Panasonic have just produced a camcorder cheaper to manufacture for them, it might even be the case the less compact wider angle lens is cheaper than the one on the TM900.
