I haven't seen any evidence of this at all. Just to check I made a continuous recording at 1080p60 to fill up a 32GB memory card. The recording lasted for 2 hours and 52 minutes and split into eight ".MTS" files (numbered 00000.MTS through 00007.MTS). I had a close look at each of the seven points where the scene spanned from one file to the next and couldn't detect any hint of frame drops or audio glitches.Are you sure it's not your player that's causing the problem? What are you using to view your clips with?
