I'm not looking for shortcuts and I certainly don't want to burn my house down over a wire.
Here's my issue:
I am running two 5' CL2 24AWG high speed HDMI cables with the net jackets from monoprice through a wall with insulation. I've got 2 dual port HDMI wall plates. I connect and install one wall plate no problem. When I go to install the other wall plate, the net jackets are so stiff and there is enough extra length on the cables that it is impossible to shove the 2 HDMI cables and the leads on the back of the wall plate into the wall so that I can attach the wall plate to the wall. I actually find it hard to believe they are that stiff but they are.
What I am wondering is if conduit is installed behind the wall and the HDMI cables are run through it, is the CL2 cable still required? If I switched to 28AWG, I'm sure there would be enough give in the cables to shove them into the wall.
If CL2 is required no matter what, does any company offer custom length HDMI cables?
How much bending of an HDMI is OK before the wires start to have issues? I guess one option is to pull the cables out, bend them enough so that hopefully the extra length gets taken up behind the wall, and run them again.
Thanks for any help.
Here's my issue:
