AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Clever ideas?
Clever ideas?
post #1 of 13
This mount positions my Samsung UN65D8000 so close to the wall, that I am unable to get my arm back there to tighten the knob that allows for the display to be tilted. If it's not tight, the weight of the display causes it to tilt back, so its facing upward (not what I want). Any idears on getting it tightened given that it must be done after the display has already been mounted on the wall?
post #2 of 13
Anyone?
post #3 of 13
Buy a different mount.
post #4 of 13
I asked for "clever" ideas.
post #5 of 13
The easy thing to do is go buy a dollars worth of washers or if your mount came with a hardware kit it should have plastic spacers to get the display a little farther from the wall...if you don't want to do that than what cables are causing the problem...power, HDMI? Here is a solution
post #6 of 13
I'm already using the plastic spacers. And the cables aren't the problem. It's simply the low profile of the mount.
post #7 of 13
It looks like a square-ish knob. Do you have a socket kit with a socket that would fit snugly over the knob? Duct-tape the socket to the end of a pvc or similar pipe/pole and tighten.... How's that for clever?
post #8 of 13
If it's a matter of not being able to tighten the knob and not the display/cables bottoming out against the wall take it off the mount tilt and tighten it and stick it back on. Have you tried getting at it from the top instead of the side?
post #9 of 13
I can't tighten it before I mount it because the tilted position prevents the brackets from grasping the wall mount - it's that low profile (even with spacers). And yes, what tightening I did do was from the top. I just can't get enough leverage from the top to tighten it adequately.
post #10 of 13
If your mount was a few inches lower on the wall, would you have enough room from the top? Ask a mechanic if there's some special tool for hard to get at places.
Are others having the same problem? Ask the folks where you bought it from, or the Geek squad, or other installers. Check for reviews of the same mount, or some thread on this forum regarding installation, mounts, etc. Or google the entire internet. Good luck.
post #11 of 13
Check the link. Maybe it's a different model, but many folks have the same problem. Maybe you can email Big Dave on page two of the user reviews. He said he made an extension for his wrench. I didn't read past his post, but maybe others further down the list have more specific solutions.
http://www.bestbuy.com/site/Sanus+-+...ount&cp=1&lp=5
post #12 of 13
If you end up having to make a tool just get a piece of 1" or 3/4" PVC and notch the end.
post #13 of 13
Oooh, now there's an idea! Thx!
