AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Sony KDL-46HX750 & KDL-55HX750 Owners Thread
Official Sony KDL-46HX750 & KDL-55HX750 Owners Thread - Page 32
post #931 of 1590
Hi guys, sorry it took so long to post. I'm a Navy Chief out here in Hawaii. So time zones are obviously different. Ok Here's what I have for my settings. I'll explain how I got to them after I post them.
Scene Select - Cinema
Picture Mode - Cinema 2
Backlight - Min
Picture - Max
Brightness - 50
Color - 52
Hue - G1
Color Temperature - Warm 2
Sharpness - 40
Noise Reduction - Off
MPEG Noise Reduction - Off
Dot Noise Reduction - Off
Motionflow - Off
CineMotion - Auto 2
Advance Settings - Below
Black Corrector - Low
Adv. Contract Enhancer - Low
Gamma - +1
Auto Light Limiter - Off
Clear White - Off
Live Color - Off
White Balance - Below
R-Gain - minus 1
G-Gain - 0
B-Gain - minus 1
R-Bias - minus 2
G-Bias - 0
B-Bias - minus 2
Detail Enhancer - Off
Edge Enhancer - Off
Skin Naturalizer - Off and grayed out
i/p Conversion Preference - Quality and grayed out
Home - Settings - Picture & Display - Below
Screen - Below
Wide Mode - Full
Auto Wide - Off
4:3 Default - Off and grayed out
Auto Display Area - Off
Display Area - Full Pixel
Screen Position - grayed out
Vertical Size - 0 and grayed out
Pro Picture Setup - Below
Color Matrix - Below
HDMI 1 - Custom
480i - ITU601
480p - ITU601
1080i - ITU709
720p - ITU709
1080p - ITU709
HDMI Dynamic Range - Below
HDMI 1 -Auto
Ambient Sensor - off
First off like I stated earlier, I have the 929 and the 750. I'm by far no expert, but have had my share of Plasma's and LED's in the past. I've always done thorough research before I buy and troll these forums often to get a good feel for which set I want. I am also a firm believer in returning a set if I am not happy with the picture. I have done that several times, and even though the retailers aren't happy, I don't make the rules, they do. I figure if your paying upward of $1500 and have the ability to return the set then get what you're happy with. I have had several of my sets professionally calibrated, one which my last before my 929 was a Panasonic GT30. These settings are probably not to different from most of the others on here, but here's how I got to them.
As far as the standard settings I started with CNET's settings. Then I tweaked the picture and brightness using my DVE Blu-ray calibration disc. I actually left my color, color temp, gamma, and white balance to CNET and here is why. When I have watched these guys calibrate my other TV's I am very inquisitive and ask lots of questions. Now take into consideration that on some of those sets they are making adjustments in the service menu. I have noticed that all the listed sites that do the calibrations on most of these Sony sets, even my 929 don't go into the service menu since most of the options are available in the regular menu. Just my guess, but since CNET and others are using their equipment to get color and grey scale as close to standard as possible, their settings should be fairly close on those settings so that is where the gamma is set to +1. The one thing I have always noticed though was the brightness and sometimes contrast is usually off a little from set to set. So that's why I adjust that with my own disc. On this set however, I read through all the posts and used steve1971's advice for the Black Corrector to Low and Adv. Contract Enhancer to Low. Then I went back and adjusted my brightness. This made a real difference in the Black levels. I even trolled the HX753 forum and Sony Europe and found out that the Adv. Contrast Enhancer is almost like LED Dynamic Control for my 929 or has some of the same principals to help with Black levels on this set. As far as Warm 2 on the Color Temp, I pretty much go along with the notion that these sites that test the color with their meters and all state that this is closest to D6500. So that's why I left it at that setting. I read on here from some people that they think it is to dull. I thinks that's because we are so used to looking at these sets in the stores with the setting ramped up to catch our attention and honestly not knowing what the standards are until you start to research and come on forums like this, we probably set our color wrong in the first place. Either way, I used to be the same way years ago and once you leave it on Warm 2 you actually get used to it. Another thing I don't think we realize is how color temp affects gray scale. I go back to the guys using instruments to test all this so I have to trust some of the reviews or a portion of them. Either way we kid ourselves thinking we can eyeball all these adjustments. It just isn't possible. As far as the HDMI settings, on other sets the limited or full has made a difference in black level, but on both my Sony's it doesn't. My sharpness is 40 and actually 42 on my 929 and read from several reviews that on these sets once you go to low it washes out the picture unlike some other sets where you can go to 0 and be fine. Anyways these are only my opinions and I hope this helps some of you just like reading through your posts helped me.
Oh one other thing I learned from my 929 settings that I got from someone on that forum that had their set professionally calibrated and I made only minor adjustments to which has that set looking awesome. If you say use these settings for night time viewing in which my room is pretty dark, and then switch to cinema 1 for daytime, keep all the settings the same except bump up your backlight +1 or 2 depending on your preference and depending on your contrast +5 it actually makes a hell of a difference for brighter rooms. Now you have a day and night setting. I am using Dish network 1080i fixed for my Satellite feed, and Sony Blu-Ray 1080p fixed for my movies.
post #932 of 1590
Backlight - Min
Picture - Max
Brightness - 50
Color - 52
Hue - G1
Sharpness - 40
Motionflow - Off
CineMotion - Auto 2
Gamma - +1
Clear White - Off
Live Color - Off
R-Gain - minus 1
G-Gain - 0
B-Gain - minus 1
R-Bias - minus 2
G-Bias - 0
B-Bias - minus 2
Edge Enhancer - Off
Screen - Below
Wide Mode - Full
Auto Wide - Off
HDMI 1 - Custom
480i - ITU601
480p - ITU601
1080i - ITU709
720p - ITU709
1080p - ITU709
HDMI 1 -Auto
Mlapd I am gonna have to give your settings a try and thanks for all the detail on how you came up with them. I let you know how they look on my set. Thanks again. Boy I bet your enjoying the weather out there in Hawaii. biggrin.gif
post #933 of 1590
Yeah, but this time of year is the rainy season. So even though the weather is warmer, it rains allot. I can't complain though. I actually had my brightness down to 48 on the DVE disc, but when I was watching a dark movie yesterday on Dish network, I noticed that the shadow detail was low, so I bumped it up to 50. Anyways, hope it gets your set where you want it.
post #934 of 1590
Your still lucky Mlapd. Here in Minnesota its been snowing like hell. The wife and I are getting out of here July of next year and moving to Arizona where its warm! Anyway I like my settings as they are but am willing to try different ones to see if it makes my set look even better. I will let you know how everything works out with your settings.
post #935 of 1590
Does anyone here feel that Sharpness level can be increased if you enable other settings like Detail Enhancer and/or Motion Flow?
post #936 of 1590
Willie you can enable either of those features and you can increase or decrease sharpness. It won't matter either way.
post #937 of 1590
I've had the TV for a week and I'm pretty happy with it for the most part. The clouding is a little bit distracting but I guess that's the sacrifice for edge lit and thinner TVs.
One problem I'm having and even though it's minor, it's a little bizarre. When I'm viewing 3D content, there is thin bright strip down the left side of the TV. It's almost as if the image is slightly shifted to the right and not filling the screen. Has anyone ran into this problem? Is there is a setting I'm missing somewhere or a known issue?
post #938 of 1590
I was more questioning whether it enhances the picture quality by doing it like that.
The reason being is that when the sharpness gets raised too high without those being enabled I noticed that some images look a bit off.
post #939 of 1590
I've seen that at times on mine as well. I'm almost certain it's the content you're viewing and not the set itself. Try some more sources of 3D content.
post #940 of 1590
I was going to say the same. Is it just where the two images overlap to create the 3D image.
post #941 of 1590
Nope Willie it dont enhance the PQ at all.
post #942 of 1590
Hey Mlapd,
Tried your settings and they were similar to the ones I have already on mine so I left mine the way I already had it set. But your settings are good though. I have my brightness set to 90 just in case your interested.
post #943 of 1590
Hey Mlapd,
Brightness set to 90! ; )
post #944 of 1590
Thats right buddy because I found that any lower the PQ is to dark. The reccomended setting is Max on many sites.
post #945 of 1590
Don't you mean contrast mate?
post #946 of 1590
Thanks for reminding me Aaron, yes I meant contrast. Thats what happenes whe :Dn you get older I guess. lol
post #947 of 1590
Lol i guess i have that to look forward to ; )
post #948 of 1590
post #949 of 1590
Alright thanks.
I was just wondering if certain settings influence other settings.
post #950 of 1590
Does anyone know if the Bravia kdl 40ex650 has comporable settings to this TV? I bought this TV in Taiwan and I'm having a really hard time finding anything in English about it, namely calibration settings! I've tried a few settings from this thread and they seem to work ok. However, my picture appears quite dim to me (I am in a bright room), so I'd really be appreciative if theres any owners of this TV on this thread that can help me.
post #951 of 1590
Have you turned the ambient light sensor off? It maybe called something different for you. But its under home - system settings.
Aaron
post #952 of 1590
Aaron
post #953 of 1590
Hi all, i come here as a new poster looking for some advice!
I live in New Zealand and our range of available TV's here is definitely limited compared to the international market .. however this particular TV has caught my eye.
My main concern is its 3D performance .. in particular crosstalk. I see a lot of reviews mention it has a lot of crosstalk (from what i understand is ghosting when not looking directly straight at the TV) .. the main reason for purchasing this TV is for 3D gaming ! well 2D gaming also , but i plan to do a bit of 3D gaming .. i built a cheap home-made racing sim setup and wish to place this TV in front of it and get immersed in the action!
Here is a picture for anyone interested.. yes we drive on the right with shifter on the left of us :P
anyway .. basciailly im concerned about the 3D performance of this TV .. without reading through 30 pages in this thread (which i will do eventually!) i was wondering how people have found this TV in terms of watching 3D movies and in particular playing 3D games from PS3 / PC ??
I really appreciate any feedback people can offer.
Edited by ReaperZ - 2/12/13 at 7:03pm
post #954 of 1590
Yea, I've turned it off. I've tried the settings on this thread but I'm saying that they often lead to a picture that is too dark. So while my TV might be similar, its not quite the same IMO.
post #955 of 1590
3D on the HX750 is very very good. My advise to you is get the PS3 3D glasses because they work better then the regular 3D glasses from Sony plus they are cheaper. That being said nice Racing Sim setup, looks cool. biggrin.gif
post #956 of 1590
+1
PS3 glasses have the polarizing filters built in eliminating many of the problems associated with the non polarizing 250 and 750 Sony glasses. You can request free polarizing filters from Sony for the 250 and 750, but considering the PS3 glasses are only 19.99 at BB, probably less hassle to just get them rather than call Sony and wait for the filters to arrive.
Once you have the filters, the 3D on the 2012 line meets or exceeds in some cases the ES8000s 3D.
One side note... 3D gaming on the PS3 will not be at the same resolution as when watching 3D movies. Not sure what the actual resolution is (perhaps someone can post the correct number) but I think it is capped at 720p.
post #957 of 1590
Guys i am from Bulgaria . I have read the many helpfull posts in this thread and have couple of questions . I bought ( replaced samsung 46D6530 cos of false advertise of full 3d , paid extra 600$ ) KDL-55HX750. I liked my Samsung but they pissed me off badly cos i was sold that tv for full hd 3D a year ago when i bought it and recently i bought 3DTV play Nvidia gf650 and when i seen the "full hd 3d " i was so pissed off , so i fought over 1 week battle with the service , shop , distributor and samsung representatives finally i scared them cos they were going to get penalties from government instances .
The two unopened boxes/units the store had , turned out to have a stuck pixels on the upper left corner , they were both produced 10/2012 . The Demo unit in store was produced 09/2012 and they said was working in the store for 28-30 days ( 10 hours each day ) had no stuck pixels no troubles what so ever , they even let me bring a computer , and play arround with it.Also the part of the stand that hooks to the tv for the 09/2012 seemed made by different material so i got the accessoaries of the 10/12 model they looked better and they were unopened . Anyway when i got back home i noticed the colors are not as good as the D6530 Samsung thought the sammy was 46" and this is 55" . I use Computer -> HDMI -> Full Range Color space (0-255 ) / Full Pixel . I dont know it seems like i am too geeky but after i got this TV every tv,monitor , phone i look like the colors are bad , white balance is off and so on so i may be overreacting and expecting miracles .
First my impressions are that the contrast is low , thought the black levels seem fine ( there isnt any clouding or at least hardly noticable , just a little lighting from the corners but its not a problem ) . I tried the frame dimming option for advanced contrast to low/medium and makes things better . But even thought i dont know is it me or sometimes i can see the color burns thought thats on HD TV shows .
My questions are , since i am in Bulgaria as i said i cant get a proffesional calibrator tech . So i tried looking at both Cnet review you guys gave http://www.scribd.com/doc/87366710/Sony-Hx750 and also http://www.avforums.com/reviews/Sony-Bravia-HX853-KDL-55HX753-46HX753-40HX753-32HX753-3D-LED-LCD-TV-Review_321/Test_Results.htmland i cant help to see that the RGB Balance charts for R G B levels are way different on both site . Cnet review calibrates the white balance with :
R-Gain: -2
G-Gain: 0
B-Gain: -1
R-Bias: -2
G-Bias: -2
B-Bias: -2
From this i understand the Gain on Red is turned -2 steps because its on like 105 % , B is -1 because its on 100 % and G is 0 because its like 95 % ,( and this making the RGB levels all on about 95 % ) then the Bias-es on all RGB r turned down 2 steps to get the R G B to 100 % .
From that logic and looking at the other review ( which seems to be UK while cnet is USA ) the RGB balance is different , the Blue is too high , green is somewhere in the middle and red is too low . The logic would be putting white balance settings :
R-Gain: 0
G-Gain: -1
B-Gain: -2
R-Bias: -2
G-Bias: -2
B-Bias: -2
Both reviews r for 55HX750 , is it possible a same partide panel to have different RGB Balances ? What about Same models to have same panel RGB balances .
P.s i am sorry if i havent posted the information correct or not provided the links right i am new to this forum . Let me know and i will corect what i must .
Also for Samsungs the serial numbers were containing the country origin of manifacture ( cos of some letters meaning like Slovakia or so ) . What about sony ? i see before the serial number itsels S01-serial-7 and the countries it is for sale are all european including UK . Should i concider my tv with a RGB balance close to that UK review or close to the USA review ? Also found other sites and all of them show very different black levels under similar settings , while one site shows 0.04 cd/m2 others show 0.13 cd/m2 which is unaxeptable for 2012 LED 3Dtv
post #958 of 1590
I haven't tried out the 3d yet, but I just wanted to say that setup that you built for racing games is pretty awesome.
post #959 of 1590
Also I have just ran the Disney Wow Calibration disk . Found out that Gamma settings of my windows or that 55HX750 are way off . I was getting 1.7 gamma where i should be getting 2.2 with the default windows settings for Gamma , which was fine with the Samsung . I tried also just to be sure the gamma on other site and it showed again 1.7 . So i had to turn the slider for the windows gamma settings . Display - Display Color calibration and then ajust the gamma almost to the lowest part ( like 1/6 up from the lowest part ) and i was getting values of 2.1-2.2 ( with the HX gamma on 0 ) obviously i could have set the windows gamma a little higher and compensate setting the tv gamma to -2 or -3 but i thought havving it on 0 in the tv is the best . Now contrast looks way way way way better .
I would advice anyone who can get access to that Disney WOW disk , to use it and help himself with the calibration , while i still am not sure for the white balance ( as i do not have a blue filter ) so i can tweak the hue red/green tint , cyan magenta - this disk helped me alot .
post #960 of 1590
I think if you went to Lcdtvbuyingguide.com and looked up your 55HX750 you might find the settings you looking for.
Edited by steve1971 - 2/13/13 at 11:17am
