AVS › AVS Forum › Display Devices › Display Calibration › Meters and repeatability.
post #1 of 7
I have a used i1pro and new i1D2.
I am beginning to suspect the
i1pro. It passed all the xrite diag program.
Anyway, I have been chasing settings using the i1pro. I don't trust the D2 calibrated with the i1Pro.
In HCFR there is a near black measure. I put the D2 on a black surface and ran the 5 readings. all 5 were identical. They showed 0 ftl and cd.
they did report .375 for red and .250 for blue and 0 for green. Interesting, so I ran the i1pro and every reading of the 5 was different. It also showed
.75 for red and .600 for blue and .200 for green and 0.0 for ftl and cd.
Does any of this make sense?
should I use offsets to get the D2 to show 0 colors?
Why does the D2 report identical reads and the pro does not?
post #2 of 7
it's totally normal for an i1 Pro to be below it's functional range on near black readings.
The i1 D2 is usually right at it's limit with black, but it's reporting 0 back, then it's probably out of range as well.
Your TV at black apparently is too dark to measure with your hardware.
post #3 of 7
hey, good to see ya.
so the i1pro will act like that? I did not put the meters on the TV. I left them on a black surface, 0.0
With absolutely no light, the D2
gave me x= .360 y=.250
Y= 0.0
Can I edit the tables to get
x= 0 y=0 ?
would that properly calibrate the D2?
post #4 of 7
technically x,y are undefined for total black.
XYZ is what the meter reads.
x = X / (X+Y+Z)
y = Y / (X+Z+Z)
if X +Y + Z = 0, well then you've got a divide by 0 error.
If they are all small but equal you'll get the equal enegry point or point E, 0.333,0.333
post #5 of 7
I am trying to understand the
info you supplied.
I have no experience in calibration.
Interesting there is no xyY for black.
post #6 of 7
info you supplied.
All the xyY data is a measurement of light.
black is an absence of light, you can't have color without light.
post #7 of 7
Joel, nicely said!
