AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Bringing everything together with the right remote
post #1 of 6
Hello everyone, been doing a lot of reading around these parts in regards to finding the right remote for my setup (Denon 1712, Comcast RNG150, and an HTPC with usb ir receiver) and I think that I narrowed it down to the following:
Refurb Logitech Harmony 650 - $49
Acoustic Research ARRX18G XSight - $70 New or $50 Used
Refurb Logitech Harmony 700 - $64
Let me know some of your thoughts on these, or any others that you may recommend. Thanks for any suggestions.
post #2 of 6
The 650 is plenty and will be easier to setup and use than the Xsight, especially since you have a cable box with no discrete power commands. Go for the 700 if you think you'll be getting more devices in the future.
post #3 of 6
Thank you for your suggestion!
post #4 of 6
Actually went with a brand new harmony one for $100 after a 50% discount. Figured it is worth the extra minimal investment.
post #5 of 6
Where did you buy it?
post #6 of 6
Direct from the logitech website. Had an old harmony 520 that has a broken screen so I called logitech and after a brief troubleshooting stint they sent me a 50% off coupon for any harmony remote (no refurbished or clearance). Should be arriving today.
  Back to Forum: Remote Control Area
