OK, so I believe I have narrowed down my projector selection to the JVC RS45.
As of right now, (still in room build process) I am planning a Carada 1.4 gain 112" 2:35 screen, projector lens will be about 17.5' from screen.
Now on to the question. I am fairly certain that I want to use a lens and if I come onto a great deal I will get one (possibly used), so....
Does anyone know for sure if the RS45 will do the vertical stretch to loose the black bars before shooting it through a lens?
I need to know if an external scaler is going to be needed with this set up. Thanks in advance.
