Originally Posted by amirm
Your question had no answer because you could not clarify it yourself what the generic term "proper placement" meant. I asked the clarifying question last night and you still came back with nothing. That someone can take your vague question and give you an answer anyway, should be an alarm, not joy. See more below.
Since you are not going to listen to my data, why don't I take the data from the other side reflecting the point you just agreed with and see if it worked? Here is the evidence put forward by Locahost on efficacy of what he is repeating here. This graph is said to show the merits of removing reflections:
What the data shows is what happens when you go from no absorbers to many. Localhost then point to the time domain chart and say, "see, it is a lot cleaner." Folks like yourself trust your gut and proceed to believe something good has happened. It is a wonderful campaign because folks put aside all science and believe what visually looks convincing.
Let's see if the graph proves that bad speakers can be fixed this way, this time, focusing on the best case scenario with maximum number of absorbers:
Note what I circled. There is a giant peak in the response of the speaker in high frequencies. What is incredible is that the peak remained despite huge number of wall acne courtesy of all of those treatments. So clearly what was bad about the speaker was not fixed.
Indeed this notion of room treatment, the so called live-end, dead-end (LEDE), apparently came about because people had speakers with poor of-axis response, leading folks to build control rooms that were heavily padded as to get rid of said reflections. We now know that such rooms are not pleasant listening rooms.
So by all means, trust your gut. The guy who buys a better power cable, looking at removal of high frequency noise on some measurements, feels good about that purchase too. Don't look at perceptual effects and double-blind testing. Or the people who advocate the same. Listen to a forum poster telling you that if you replaced the speaker with a lamp and proceeded to paint the wall he is telling you in black, that what the rest of the room is no longer lit by that lamp and only one magical ray is hitting your eye from that lamp!
And that its color temperature magically became perfect....
And that its color temperature magically became perfect...."What the data shows is what happens when you go from no absorbers to many. Localhost then point to the time domain chart and say, "see, it is a lot cleaner." Folks like yourself trust your gut and proceed to believe something good has happened. It is a wonderful campaign because folks put aside all science and believe what visually looks convincing.
Let's see if the graph proves that bad speakers can be fixed this way, this time, focusing on the best case scenario with maximum number of absorbers..."
A classic case of not having a clue as to what 1.) was the purpose of the exercise (despite description) and 2.) erroneous conclusions based upon having no clue regarding what the example attempted to show.
Which should serve as a most adequate example of how additional conclusions should be interpreted in light of such glaringly incorrect interpretations.
First, the example has NOTHING to do with the speaker response. It could be a unit with the most amazing response in the universe or the worst, or anywhere in between. The issue is superfluous.
The purpose of the example is simply to show the effect of removing non-minimum phase reflections by incrementally applying absorption to incident boundary points, thus showing the corresponding 1:1 reduction in resultant comb filtering as a result of the reduced superposition of direct and indirect signals displayed in the time domain.
There is NO other purpose to the example than this. It does not propose to suggest an acoustical response goal of any type. It simply illustrates the nexus between the causal superposition of direct and indirect signals and the resultant frequency comb filtering, and to illustrate that is the superposition of direct and indirect signals is reduced or eliminated, that the derivative comb filtering is reduced.
Also, the example has absolutely no connection in any way to LEDE/RFZ. NONE. There is absolutely no reason for that term to even be mentioned, except that someone apparently hallucinates a nexus. Aside from bearing absolutely no semblance to the acoustical response model, anyone with half a clue regarding LEDE would know that any signals outside the ISD are mitigated with diffusion. A similarly absurd nexus could also be made with chocolate chip cookies.
And I will go one step further to categorically state that it is NOT a correct procedure to attempt to remove every reflection! Again, this example was performed simply to provide a visual reinforcement of the concept that by removing indirect reflections, that the resultant comb filtering is reduced. In fact, all reflections are not evil and all comb filtering is not detrimental.
The example merely systematically illustrates the progression from an example illustrating the response for a particular speaker in a particular room, and then proceeds to move from an untreated space complete with comb filtering, to a predominantly dead space, removing reflections and illustrating that as the individual reflections are removed, that the degree of comb filtering is also reduced.
It shows HOW the cause (indirect reflections) and the result (an interference pattern called comb filtering) is related. Nothing more, nothing less.
The example also does not make any attempt to recommend any type of treatment response.
And to clarify for anyone who has mistakenly assumed that anything asserted above regarding absurd claims that room treatment will somehow correct for a speaker's direct response, there is NO claim whatsoever that room treatment corrects for the source's direct signal character. Such a notion is 100% FALSE. The use of absorptive treatment strategically placed simply removes anomalies introduced by room-speaker (direct - indirect) signal interaction (superposition).
It is completely incorrect to assert that room treatment in any way corrects for the character or quality of a speaker's direct signal. Unfortunately, exactly such a thing has incorrectly been asserted here.
Please do not let this misinterpretation cause any confusion.
So in my defense, I put forward this article:
