AVS › AVS Forum › Video Components › Home Theater Computers › For Mfusick - Sneak Peek
For Mfusick - Sneak Peek - Page 4
post #91 of 102
Originally Posted by assassin View Post
How does pooling have any tolerance at all?
I am not sure I even understand this question... That's the point right ?
post #92 of 102
I am not really sure why people are hung up on the whole pooling or spanned idea anyway. As I mentioned he wanted the drives to appear as 1 large drive and wanted it done in the simplest way possible.
As he has (or will have) a server with duplicate data he isn't worried about data loss. We informed him multiple times that data could be lost in event of a drive failure and he understood those risks.
Again, not how I would use it necessarily but its also not my HTPC.
post #93 of 102
Originally Posted by hockeyrcks9901 View Post
To put it very simply, a spanned drive is similar but does not have fault tolerance.
I believe that spanning is done by hardware and pooling done by software for the most part.
Assassin's question was directed at the fact that hockeyrcks9901 seemed to imply that a pooled drive has fault tolerance, whereas a spanned drive is similar but doesn't.
As far as I can tell, they're both the exact same thing and both don't have any fault tolerance...
post #94 of 102
Perhaps some people are confusing spanning with striping?
post #95 of 102
You are correct. I misread the post.
post #96 of 102
If it's just media it might not be ultra important.
I mean the TV shows I record.. I could probably live without them. lol.
post #97 of 102
Assassin where would someone buy a case like that. ?
post #98 of 102
You didn't ask me, but really?
In a less snarky form http://www.shop.perfecthometheater.com/HTPC-aluminum-chassis-S21T-IR310-Black-HTPC-S21T-IR310-B.htm?productId=10
post #99 of 102
love the let me google that for you link... LMAO
post #100 of 102
You don't see many of these builds .... but such a slick looking case.
Assassin have you done any more of these type of builds recently ?
post #101 of 102
Of course.
post #102 of 102
What's the coolest build you ever did ?
