Go into to your eco setting and make sure the timer is off, if you are running scrolling bars the set considers it "No Signal" and will shut off to conserve energy. I was having a similar issues and Samsung tech said my set was over heating and may need serviced.Originally Posted by ONUOsFan
I must be doing something wrong then, because mine shuts off after a few minutes.
Looking around for some good picture settings... Just got my 7000 and it's my first plasma. Most settings I've seen online are using movie mode, but I'm not crazy about the way it looks.... It seems very orange to me. Also pretty dim, especially during the day (my set is in a room with a lot of windows). I don't want to "torch" my panel, but if anyone has any ideas do settings that are a little better for bright rooms than, say, the CNET settings, it would be appreciated.
Also, any "limits" I should be aware of for the first couple hundred hours in terms of cell light, contrast, etc to avoid any burn in issues? Haven't seen anything yet that didn't fade within a few seconds of watching something else, so I'm not overly concerned about it, but don't want to do anything stupid either. I've been playing with my settings a lot, but right now I'm on standard mode, 13 cell light, 85 contrast and pretty much everything else default.
