Originally Posted by BCook67
Hello all. I've noticed with my new Samsung PN51E7000 plasma that I have a perfectly clear image when there is little movement or few items on the screen, but in scenes where there is fast motion or large groups of people I get a very pixelated image. For instance, a car sitting still is perfectly clear, but as soon as it speeds up the entire image quality degrades significantly. My fiance and I also noticed the effect while watching Happy Feet 2 on Blu-Ray.......in a scene where there were two shrimp swimming the image was crystal clear, but as soon as there was a whole school of shrimp swimming the image became very pixelated and choppy. I've searched the forum and found no one else mentioning this issue, and also contacted Samsung's tech support (completely useless), so I'm turning to you guys to know if this is common for this particular TV, plasmas in general, etc. The TV is brand new and relatively large so I don't want to chance sending it for servicing if this is a normal issue, but I honestly don't know enough to make the call myself. It is the same issue using both the cable box or a high-end Samsung Blu-Ray player (both attached via HDMI). Thanks for any help you guys can give me.
I have the same TV as you and do not have this issue at all. Actually you should have the opposite of this occuring. One of the benefits of plasma is the speed rate for motion. It should be way better than LED/LCD. You have an issue with your TV for sure. No pixelation should occur.
