Originally Posted by
ferl
Just agree with him and perhaps he'll shut the **** up. Just know that the monkey is never wrong and you should consider yourself fortunate that he shares his infinite wisdom.
This is directly from Panasonic on plasma buzzing:
In response, I routed your email to our technical advisors who have advised
the following:
Plasma panel buzzing is a normal phenomenon. They work on a totally
different principle to colour televisions and have different operating
characteristics.
The level at which the operating buzz becomes noticeable is always
subjective, one person may hear it whilst another does not.
The following points help to understand the factors surrounding the
buzzing:
The picture scanning drive circuits operate at high frequencies and powers.
It is these circuits that cause the buzzing sound. The circuits are used to
create both the picture and reuse energy to keep the unit efficiency high
and panel heat emission low. This over-heating control is very important on
the panels that do not use fans i.e 37” and 42” The resulting loss of fans
makes for a quieter panel operation...
...The buzz will appear more concentrated at the sides of the unit since this
is where the power circuit boards are situated.
Because we do not employ cooling fans, the buzz may be heard in very quiet
surroundings. Plasma buzzing is normal and will always occur, but the level
of buzz is what matters.
Generally speaking the buzz will only be heard in quiet surroundings [with
low levels of audio from whatever sound system used] and with the user
seated too close to the panel [less than12’ for 42” and 10’ for 37” panels.
A typical scenario is using the panel in the middle of the night when
listening to news broadcasts at low volume. In this situation buzz might be
heard during the silent breaks in the audio, but not so much during speech.
This is not abnormal nor does it indicate a faulty panel.
If the buzz is heard above normal ambient daytime noise and audio levels at
more that 12’ a problem might be present.
The method of panel installation will also affect the amount of noise
heard. Wall mounting the panel will cause buzz emitted from the back of the
panel to be reflected off the wall and into the room more than if the unit
is located on the pedestal which is seated 2 to 4 feet away.
Hard wall surface i.e. painted/wooden panels will be more effective
reflectors than say walls that are covered in softer finishes, wall papered
or curtained.
Changing the picture mode in the picture settings menu between
dynamic/normal cinema will also reduce the level of perceived noise since
this affects how much power the panel is processing and this the level of
power produced.
Having too much brightness and contrast with the dynamic mode setting on,
can overdrive the panel and cause louder buzz levels with strong picture
signals i.e. DVD or Sky digital signals. Changing these settings can lower
the level of buzz produced. Use ‘normal’ picture mode and lower
brightness/contrast settings to reduce this effect.
It is normal for the buzz tone and level to change the picture content
because the panel drive circuits are processing different amounts of power
and adapting their drive cycles.
Plasma panels do not run in total silence. They do buzz as a normal part of
their operation but this level of buzz is quite low and may be
intermittently noticed in quiet surroundings.
Please ensure these facts are understood and check your panel against a
dealers display unit before requesting service since abnormal levels of
buzz are not always ‘abnormal’ but just the normal operating buzz of plasma
technology.
Enjoy your slice of humble pie. I hope it shuts you the **** up. It is obviously from the high voltage drive system required to cycle the phosphors.
Edited by Icon13 - 2/14/13 at 10:37pm
