Originally Posted by deria
In my earlier "initial impressions" post, I mentioned that I would check for the hockey-pops phenomenon.
I don't see anything wrong. I watched about 20 minutes of hockey highlights -- the only changes in brightness I saw were when people took pictures during big moments (ie: exactly what I would expect to see). If you rewind, the flashes come at exactly the same time and have exactly the same duration every time.
I definitely didn't see anything remotely resembling what that YouTube video that was posted earlier showed.
I watched in standard mode because in movie mode the ice looks yellowish with the CNET callibration settings. The only change I made to the standard mode was to turn off the eco sensor and to lower the sharpness to 0. Otherwise, I left everything alone.
As far as I'm concerned, the TV showed me exactly what I would expect to see if I was sitting in the arena.
The only thing I'm having trouble getting used to with this TV is the faintly discernable flickering (due to the refresh rate). I guess I'm just sensetive to that type of issue. It seems to be a general quality of plasma, though, so I'm not worried about it. The incredible picture quality more than makes up for it.
" I watched in standard mode because in movie mode the ice looks yellowish with the CNET callibration settings. The only change I made to the standard mode was to turn off the eco sensor and to lower the sharpness to 0. Otherwise, I left everything alone."
Standard mode is the most inaccurate mode on the E8000.. If you want a whiter white choose movie mode, then select in color temp warm 1..
