AVS › AVS Forum › Audio › Speakers › Leaving Pro Audio For Hi-Fi
post #1 of 9
I just sold my Event ASP8's and JBL LSR6328's. I'm out of music production and am getting into hi-fi.
I tried keeping the JBL's because their crystal clear highs are phenomenal, but when it comes to pure dynamic power, they fall flat, like they're supposed to. If I was just a classical listener, I wouldn't have any problems with studio monitors. The problem is that I like to rock sometimes.
I've got a pc based system, complete with a good mixer, so hookup options aren't a worry. I've got $2,000+ to spend and so far, I think I can get what I need if I buy used.
I've been looking at a 2.1 setup and am having trouble sifting through all the options, I really need help. I've been to Best Buy and other audio houses, but the salesmen are either morons or they just care about their commissions.
I'm in a 20x20 room and need to fill the house (not very big) if needed. I don't need home theater options and have no preference between powered/unpowered speakers. I'd like to steer away from floorstanders and go after desk or stand mounts with the sub on the floor.
Like I said, I like to rock, so if I could get a setup that punches me in the stomach and then serenades me with lullabies, I would be very grateful. I appreciate any suggestions.
post #2 of 9
Have you considered any of the DIY options?
dbl
post #3 of 9
Are you planning on expanding to a 5.1 or some sort of home theater system, or you plan on keeping it a 2.1 dedicated music hi-fi system? Just so I don't recommend something you won't/don't need
post #4 of 9
If you want bookshelf speakers, and you want a system you can crank, you need a receiver with bass management.
Onkyo 807 $500
Ascend 340 $600
Rythmik FV12 x2 $500 ea
post #5 of 9
Awesome, thanks for the recommendations. I'm just wanting a 2.1 and don't have any desire for home theater.
I have considered DIY; however, that's a can of worms that I don't really have time to open unless I can save a good amount of money over buying used. Also, I don't have the desire unless there are clear-cut plans and highly anticipated results.
post #6 of 9
You may or may not be interested - however, you can check into
some B&W 805 Matrix speakers here $799
http://www.spearitsound.com/special.html#Speakers
And here
http://www.ebay.com/itm/B-W-MATRIX-8...item519e1da2ce
post #7 of 9
Well I linked you a 2.2 setup. You need bass management to remove the <80hz content from your mains, and redirect all of it to your subs. This allows your speakers to play cleaner and louder than if you run them full range. That is why I linked you an "HT" receiver, you dont have to use more than 2 channels, and the amp will actually output more power when run 2 channel. I also recommend dual subs for improved system integration, and flatter in room bass response. A single sub requires careful placement consideration to avoid massive peaks and nulls at your listening position. Multiple sub placement will help to equalize the bass by filling in from a different location.
post #8 of 9
Thanks for the advice, it's much appreciated. I will be researching these options.
post #9 of 9
I was sort of in the same boat as you. I have my Dynaudio bm5 setup for music production/stereo playback and started to look for a nice 2.1 hifi option or 5.1 home theater while setting up my place.
I ended up going with Klipsch rf series (floorstanding) setup for speakers and an elemental designs subwoofer powered by an old Denon reciever. The space is similar to yours and the entire place is filled with sound. I actually use the Klipsch's for reference now as I have gotten very used to the sound. Something I found out when going from Pro Audio to Home Audio is its a very different world.
Such differences are; Companies like dynaudio say their home theater line is 2-3 generations ahead of their pro audio line, that really shocked me as we expect Pro Audio to be the best. Behringer is not looked down on! That was the biggest shock to me as Behringer is usually regarded as total crap, but in the HT world its fine. Most likely due to Behringer not being in a recording chain, but only playback chain.
  Back to Forum: Speakers
