I have an older kicker solo x 18" 04 model, It has been taking space up in my garage for far to long and I want to build a box for it, Last time I used it it was in a 10 cube 300sq inch of port burp monster box for spl in a old blazer, This time however I would like to see what it can do musically in my house/ garage would even like to maybe give it some use in my ht possibly one day.
My standards and sq needs are no where near the level of most of you guys around here, but I would like to see what this thing can do with your guys help if you don't mind,
So basically what type of enclosure would you guys recommend? I'm used to car audio sealed/ported you know the usual's. I would like to try some sort of horn, trans line, or whatever else you guys recommend, I'm going to be powering it with a older qsc mx1500 amp.
So any idea's? pointers?
Thanks in advance
Thanks in advance
