Forget the Casio Hybrid, there is nothing to compare between the K750 wich is a really good home cinema projector and the bad picture of the Casio !
For the moment it's really a good surprise, the ACER K750 can produce very good blacks without using any artificial device like the D.I., you can fin a dedicate RGB adjustment option in the menu and also a CMS in 3 dimensions (this is a huge improvment after the H9500BD). When you switch on the projector, you are able to have the picture after one second.
Here the first pics of the picture menu, the CMS, and the RGB balance :
