AVS › AVS Forum › HDTV › HDTV Technical › Need a small Charter cable box
post #1 of 8
So, I have a tv mounted above my closet in my bedroom and only have a coax ran to it. Recently, I've been thinking that it would be nice to have premium channels if at all possible.... So, what I'm needing is a box that is small because I don't have any shelves for it, I was hoping to possibly Velcro it to the back of my 32" tv. Does anyone have any suggestions? Does charter offer any small boxes ? Thanks!
post #2 of 8
The only place you can get an cable box (HD or SD) is from the cableco. One exception is a TiVo with a CableCARD to rent from Charter, but they aren't small.
If you only want SD, they may have a smaller box, but it varies by location. Call them or better yet stop by one of their offices.
Another suggestion is to mount it in a closet and get an IR extender for the remote. Yes, you have to run cables from the box location to the HDTV.
post #3 of 8
Charter does have a smaller size HD cable box that can be connected via HDMI. I have enquired about it myself. But you have to specify you want the smaller size box, and they may have to order one for you based upon availability.
post #4 of 8
Would you happen to know the model #?
post #5 of 8
Are you looking for an HD box?
post #6 of 8
Anything small enough, HD would be better though.
post #7 of 8
If you velcro it to the back of the TV how are you going to use the cable box remote. If possible find another location for the cable box and run HDMI from the box to the TV. Monoprice has inexpensive cables that should work.
post #8 of 8
Couldn't I use some sort of IR eye? The only other place I could put the box is in the closet, but I would still need some sort of IR. Where can I buy a IF eye at? Alao, can I buy my own cable box or do I need to rent it from charter?
  Back to Forum: HDTV Technical
