AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › A-Bus Audio Distribution ?
post #1 of 3
So my Dad has an A-bus audio disribution set up. It uses line input for audio distribution.
What should the input to the a-bus system be? Line out from the receiver? What output is that? Can you use the subwoofer output? I think you need a non-amplified source so a speaker output is not acceptable, or is it?
Maybe I am missing something in all of my searching online for some additional info for the input source. We are planning on getting a new receiver and tv (his went kaput last week), but I wanted to get a handle on how to feed the home audio distribution from a newer receiver.
Any help would be greatly appreciated.
post #2 of 3
Needs to be a fixed, line-level (non-amplified) output - really should be a "source", but a pre-amp output from an A/V receiver can work. If the receiver has a "tape loop record out", that can work, too.
Definitely not a speaker or subwoofer output.
Unless you're planning to use multiple sources (Radio, CD player, etc.), just plug the source component into the A-Bus directly. And that's only an issue if your A-Bus hub only accepts one input. If it supports multiple, run each source directly, using a Y-cable/splitter if needed.
Jeff
post #3 of 3
Look for a 'networked' AV receiver, so you can listen to Pandora and internet radio. Onkyo seems to be a popular brand.
Read the AVR manual before buying.
  Back to Forum: Home A/V Distribution
