Ok folks I am trying to do something alittle different here so finding the information is alittle tricky. I figure since I am building a HTPC why not use software to decode my audio (maybe with some future room correction software) and send out 8ch LPCM to an external DAC. This way I could avoid having to by an expensive pre/pro and instead I can just buy an 8ch pro type DAC with a volume control.
Here is where the confusion starts .... the details. The only way I can see sending out 8ch LPCM is over HDMI, but all the pro audio multichannels DACs only accept firewire or spdif (is that 2ch or 8ch ?) Do filters like ffdshow allow my computer to decode the 5.1 and 7.1 compressed formats and just send out the 8ch LPCM ?
My motivation is I think I can spend money on a quality multichannel pro DAC and use my HTPC to decode the 5.1/7.1 formats and get better performance than spending the same money on a consumer pre/pro and bitstream from my HTPC.
Anyone else tried to do something like this ?
The Lynx mentions having drivers for WDM and ASIO.
