AVS › AVS Forum › Display Devices › Screens › DIY Screen Section › One paint
One paint - Page 2
post #31 of 32
Originally Posted by damthrill View Post
Is there not any local store at which I can buy this pearl other than menards or online? I am on west coast.
Nope.
You can try Dutch Boy Pearl Luster #DB1201 if you have an actual "Dutch Boy" Store. They will probably have to order it though.
Really.....getting it via Amazon is the best possible route to take.
post #32 of 32
I am non partisan in this topic. But I have asked a couple of times what the fabric costs. How much is it for a 92 inch screen worth of material? You must have some idea? I can tell you that I will try both. But, there is so much more flexibility in paint.
As a matter of fact, all fabric has color in it which is a form of paint.
What does MFG stand for?
I will also not entertain fabric if it is going to get into the hundreds, I just won't. Otherwise I will also try a fabric screen. But first is paint period.
I am wondering if I should have just got the $12 board instead of the Plas Tex? Will the plas tex sit fine with just one 1x4 in the middle? the twb seems stiffer.
I just wish I had some time to start assembly of the frame.
Go to http://www.rosebrand.com/category12/...n-screens.aspx
Be inventive.
  Back to Forum: DIY Screen Section
